going crazy with f250
What State you in?
Can you post picture of that truck rear suspension and driver's area so we can see how many miles it really had.
I had several that had over 200K so there wear/tear.
How much you paid for that?
5.4L isn't bad. If it miss it coil packs or spark plugs issues.
Had one with 246K miles but coolant ate alum head it still running but pour coolant so fast.
we are in ms. and yes same st i purchased it in. i cannot post picture of it tonight as it is still at ford at this moment. talked to service manager at our other ford dealership. he is telling me it could be oss. does oss have anything to do with speedo? and are oss and iss same part? he says no. says one is mm longer is this true?
When I wasn't knowledge with volt multi tester couple years ago. I think you can test with volt multi tester on vss wiring.
I cut all plastic tubing that were wrap on Vss wiring. Found near Transmission. It was full of green corrosion.
Should say clearly. Wiring from Vss sensor on rear axle I trace to find where bad wiring it was near by transmission.
I am not expert on Multi Meter but think OHM will do? Wait for expert to chime here.
#29
If you're asking on how to find a break in wiring, set your multi-meter on the resistance setting (look for the "ohm" symbol). Then push one probe on one end of the wire, and the other on the opposite end of the same wire. If all is well, you should see zero ohms of resistance, or somewhere close. If it shows infinite resistance, the wire is broken or the connector is badly corroded, either way it's not doing it's job. This may require long leads and a little creativity here, so be patient.
#30
jhales91
15
11-14-2020 03:21 PM
Jude Hosey
1999 to 2016 Super Duty
02-02-2017 08:12 AM
Firefighter 1406
09-09-2014 08:55 AM
