how to replace steering box? - Ford Truck Enthusiasts Forums
Old 08-15-2011, 03:21 PM
ravens fan's Avatar
ravens fan ravens fan is offline
ravens fan is starting off with a positive reputation.
hey goys i have a 91 150 im wondering what the best way to go about doing this is, do i go at it from the bottom and undo it? it seems pretty simple but is there anything i should know about doing it, got my reman steering box today... mine old one is hard to keep between the lines lol
thanks!
Old 08-15-2011, 03:47 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Old 08-15-2011, 04:41 PM
Slip ford man's Avatar
Slip ford man Slip ford man is offline
Slip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud ofSlip ford man has much to be proud of
I hope that you are strong...heavy as heck one handed, other hand busy starting the bolts, and a awkward position under the truck...be very carefull not to cross thread the bolts, soft cast/threading's in it..
Old 08-15-2011, 05:05 PM
ravens fan's Avatar
thanks guys and yeah im gonna have my brother help....i couldnt believe how heavy it was when i got it today lol
Old 08-15-2011, 05:23 PM
ravens fan's Avatar
is the pitman arm puller a must need? ir is there another tool that can be used?
Old 08-15-2011, 06:04 PM
bladez51's Avatar
bladez51 bladez51 is offline
bladez51 is starting off with a positive reputation.
Quote:
I have never done this job, but I understand that the Pittman arm can be a bear to remove. You will most likely need a good puller and it would not hurt to have a torch handy just in case.
A friend of mine who's been through these jobs suggested putting a 2x4 across the engine bay under the hood and tie the steering box from it so it does not drop when you remove the bolts. Also you can use it with a pulley or similar set up to hold the new one while you bolt it back on.
I might try doing it to my truck too. Those things seem to wear out pretty damn quickly. My truck only has 79K miles and it already shows signs of steering play
Old 08-15-2011, 09:11 PM
ravens fan's Avatar
where can you get these pullers at? would napa have them? and i know what you mean mine has an excuse though with 233,000 miles and big tires lol
Old 08-15-2011, 09:25 PM
Encho's Avatar
How about internet? the one i used costs around $19, and even less. The puller is a MUST, there are some conical ones which are a little pricier but apparently work even better. Get the K/D tools brand, they're very tough.
Old 08-15-2011, 09:40 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
You can rent or buy one, but it's a requirement. There is no way you're getting the old one off without one. If you are a strong guy you can hold the box up with one hand and thread the bolts in with the other. I did it but my chiropractor was pretty PO'd at me.
Old 08-15-2011, 11:50 PM
ravens fan's Avatar
thanks guys,, ill prob ask a mechanic i know with a garage if he has one before i go out and buy one
Old 08-16-2011, 10:49 AM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Azone will rent it for a small deposit, like $20 and you get it back when you return it.
Just did my '89 F150. Ya, it's a bear to hold up there and get the bolts started. Another set of hands would be great(if you find a set). I got it wedged up in there and wiggle a bolt in. Yes, don't cross thread it as it will likely strip the box holes out. Be careful.
RHD Steering Box Blue7.3 Australia Chapter 18 09-01-2014 06:07 PM
Steering Box F-600 or Toyota? Steve 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-07-2014 08:27 AM
talk about being a monkey...steering coupler aka rag joint woodtrucker 1994.5 - 1997 7.3L Power Stroke Diesel 7 12-24-2013 04:44 AM
Steering box on outside of frame MTcountryboy 1973 - 1979 F-100 & Larger F-Series Trucks 0 06-04-2010 04:29 PM
Steering gear box 1956 Mats Nilsson 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 04-10-2010 09:18 AM
Tags
1987, 1996, 96, box, change, changing, f150, f350, ford, international, ranger, replace, replasing, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
