Starter Removal !?!?!?!?! - Ford Truck Enthusiasts Forums
Old 08-15-2011, 03:07 PM
1979F-150Man 1979F-150Man is offline
1979F-150Man is starting off with a positive reputation.
1990 F350 460 4X4. Removed bottom bolt. Around 10-11 o'clock there should be another bolt, correct? I see non. The starter moves a little but is still very firm. There is nothing else holding the starter in besides the 2 bolts correct?
Old 08-15-2011, 04:05 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
There should only be two bolts if I remember.... One on the bottom and one directly across (on top) from the bottom one..
If you have both bolts out, most likely it is hanging on the thin aluminum plate between the engine and trans, it may have a burr where someone has tried to put the wrong starter on it or just messed up an install... It is a close fit, it has to be as this is what aligns the starter to the flywheel..
Old 08-15-2011, 08:42 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
The bottom one goes in from the front, the top one goes in from the rear.
Old 08-15-2011, 09:03 PM
Quote:
RIGHT!!!! I forgot about that!! Thanks
Getting old is H***
Old 08-16-2011, 12:44 AM
Right after I posted this I went out and realized the top bolt came from the other side. I had a Duh moment. Starter cam out and the new NAPA one went right in. Thanks for the replies.
Old 09-11-2011, 09:13 PM
lvin4jc's Avatar
lvin4jc lvin4jc is offline
lvin4jc is gaining momentum as a positive member of FTE.lvin4jc is gaining momentum as a positive member of FTE.
Thanks! Couldn't figure it out, did a search and found this, perfect!
Old 09-11-2011, 10:11 PM
IowanStraight6's Avatar
IowanStraight6 IowanStraight6 is offline
IowanStraight6 is starting off with a positive reputation.
Napa starter? O well different strokes for different folks
1995 f150 4.9 straight 6 twistj77 New Member Introductions 1 08-02-2016 08:38 AM
Trouble removing starter Daniel_3168 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-06-2016 01:59 PM
F350 Starter Raymond 1999 to 2016 Super Duty 1 10-23-2015 09:43 PM
stripped starter bolts reflections 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 03-07-2014 10:14 PM
Help, 360 starter installation problems AZRRC 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-21-2014 01:11 PM
Tags
1983, 1997, 460, 97, bolts, duty, f250, f350, flathead, ford, heavy, hold, location, picture, remove, replacement, starter, tbird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
