P0171 and P0174 error codes on 2004 Expedition XLT 4WD - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 08-15-2011, 01:26 AM
LastKahuna007 LastKahuna007 is offline
LastKahuna007 is starting off with a positive reputation.
Hi, I have a check engine light on causing my suv to have jumpy throttle and stalling issues when the gear is in drive. I have a Ford Expedition XLT 4WD 2004 4.6L engine. I have gone to Auto Zone where they checked the codes and told me that it was an error associated with an O2 sensor. Was not sure, so I went online to investigate it. Found these things:
1. Clean the MAF(Mass Air Filter) with electronic cleaner. (Heavily Spray the MAF).
2. Wait to dry and do it again....... Install MAF
3. Issues with fuel injectors (being dirty).
4. DPFE issue being faulty........ Or a EGR faulty.........
I'm not a mechanic by all means but can change brakes and small jobs like that. Just wondering if anyone can give me some advice as to where I should start. Step one seems like the idea but I have already tried that. Did not work. Fuel injectors too, not work. Need some advice. Thanks so much for taking the time to read this.
Old 08-15-2011, 10:49 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
The problem is due to a cracked $11 rubber elbow at the rear of the intake. You can usually find it at an auto parts store in the red package HELP section part #46017.
Here's one of my posts that has a picture of the PCV sytem. The elbow is in the red circle.
http://www.ford-trucks.com/forums/10...l#post10502496
Old 08-15-2011, 11:30 AM
Thanks for the advice and the picture that shows the location. Will let you know how it goes.
Old 08-30-2011, 07:50 PM
Could Not locate the Elbow. Similar Found
Found something similar, (elbow piece connecting to some other hoses) but it appeared to be ok. Not cracked at all and looked ok. This guy at Lincoln Mercury told me that it may be a faulty DPFE sensor. So, I replaced that. It did not resolve the issue. How much will Ford charge to do a diagnostic on the vehicle? I had asked him but it appears he does not sound like he knows or he is not sure of himself anymore. I have already paid 70.00 dollars for the sensor at employee discount. I went to Auto Zone to get the read outs again and these came up. P2197 Heated O2 sensor Bank 2 Sensor 1, P2195 Heated O2 Sensor Bank 1 Sensor 1, Along with P0171 and P0174. Second question, will a Ford mechanic know which sensor is faulty and replace that one or two; or will he just say the whole unit is bad and charge me some 500.00 to 1000.00 for the fix. I am guessing that the diagnostic charge will be something like 100.00 dollars or so. But who knows??????? Need some advice as to what to do next. Thanks for reading.
LastKahuna007
Old 08-30-2011, 08:40 PM
Everything about those 4 codes you're getting screams vacuum leak. Look again.
Old 08-30-2011, 10:44 PM
Sorry, I will check again. Thanks So much for your time though. I will let you know the status.
Old 08-30-2011, 11:36 PM
LeeLeadingham LeeLeadingham is offline
LeeLeadingham is starting off with a positive reputation.
Helpful tip to finding vacuum leaks:
Take wd-40, spray all along every vacuum line. When you hear the engine rev up, then you know you have found it.
Old 08-31-2011, 09:53 AM
Quote:
WD-40 sounds messy, why not use carb cleaner instead?
Old 08-31-2011, 01:37 PM
R&T Babich R&T Babich is online now
R&T Babich has a good reputation on FTE.R&T Babich has a good reputation on FTE.
Quote:
Originally Posted by alloro View Post
The problem is due to a cracked $11 rubber elbow at the rear of the intake. You can usually find it at an auto parts store in the red package HELP section part #46017. ...
That part is for a '97-'98.
I don't think our 2003 or LastKahuna007's 2004 has an elbow like that.
Old 09-04-2011, 09:14 PM
Talking It's Fixxed Finally..... THANKS......
It was a hose that was leaking. I could not locate it immediately due to other hoses that were atop of it. If you're looking at the engine from the passenger side of the car it was located under the 4 connector hoses. I got the hose from Ford it was part number 2L1Z6758GA and it was called a tube assembly PCV. I replaced the hose. It actually took me awhile to replace it due to my inexperience but I got it done. Thanks to everyone here. I really appreciate it.
Old 09-05-2011, 12:42 AM
Works as well.. Sometimes you only use what you have at hand, and that was the only thing I remembered ever using on that kind of problem!
P2196 and P0171 Codes cant figure out jeremymsmyth 1997-2006 Expedition & Navigator 1 08-13-2016 10:29 PM
Multiple Error Codes awojtowicz 1997-2006 Expedition & Navigator 2 03-30-2016 07:00 AM
2006 Expedition 5 Error Codes JPG7 1997-2006 Expedition & Navigator 4 06-12-2015 11:28 PM
Lean Issues Read Entirely nboyer71 1997-2006 Expedition & Navigator 1 04-04-2014 12:03 PM
1999 F350 V10 mysteries CapeFerreloMetal Modular V10 (6.8l) 23 09-18-2010 09:17 AM
Tags
2003, 2004, code, codes, error, expedition, fault, ford, fuel, injector, lincoln, navigator, o2, p0171, p0174, p17, po171, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
