1989 F150 horsepower gain
on
HA!.. I got some bad news for ya there.. a stock 5.0 of this vintage was rated at 185hp but I seriously doubt it made anywhere close to that.. more like 150hp. And a catback exhaust and ignition advance isn't gonna get you 35hp, I doubt it adds any HP actually though it will add some TQ.
The single best thing you can do to this motor is change the cam, the comp 31-255-5 C&L kit will give you exactly what you want in terms of low-mid rpm boost particularly when paired with longtube headers, and it won't break the bank either. It's a lot of work to change a cam but no other single upgrade will provide as much gain on this engine... it should put you into the 250-260hp range and 325-350tq range with longtubes.
okay heres the details.. its a regular cab longbed. rear wheel drive. and its strictly a street truck. 4 speed trans. 5.0 with completely rebuilt top end. msd iginition and flowmaster exhaust. but i still have the original manifolds and cat on there. and yea i wish i could just add more punch in the low end. i mean its not that powerful until i hit about 40-45 mph. then it just takes off. and as far as cams are concerned.. what can i get that will work with the whole speed density engine management?
Are you just ignoring Conanskis advice or can you not see it? Without changing the SD system to a MAF system, you're pretty much limited on cam selection.
As Conanski said, that cam and long tubes are your best bet. Yes you can do a cam swap with the motor in, just have to remove the radiator and such.
1985tullyhowell
18
10-02-2013 10:30 PM
DRanchero
07-22-2003 10:56 AM
