your egr valve needs to be cleaned or replaced sounds like its getting stuck open
sorrey that prints small when I cut and paste stuff
heres one that reads better
P0402 C* Exhaust Gas Recirculation Flow Excessive Detected EGR Valve Position does not match desired, limits based on
engine speed / load.
EGR Valve stuck or sticking - EGR Valve Position Sensor Bias - EP
Superheats the coolant..... superheated coolant cannot expand under the heads...the 6.0 has torque to yield head bolts. Pressure lifts the heads and the gaskets are compromised.
Sorry - was confusing the EGR cooler with the engine oil cooler... however when one fails, the other isn't far behind. If the ENGINE oil cooler plugs, then my statement holds. Again I apologize for reading something that wasn't really there.
