Trimming out carpet around pedals and steering - Ford Truck Enthusiasts Forums
Old 08-14-2011, 06:07 PM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
I am looking for a new way to trim out my carpeting around the pedal arms and steering column shaft on my 54. In the past I have carefully trimmed out the carpet and melted the edges of the carpet to prevent unraveling. How does everyone else do it? Anyone know of some good grommets that may work? Any ideas?
Old 08-14-2011, 08:30 PM
dongc1's Avatar
dongc1 dongc1 is offline
dongc1 is starting off with a positive reputation.
I bought some of the grommets to go around the dimmer switch. They worked fine around the brake & clutch pedals.
Old 08-14-2011, 11:04 PM
mechmagcn's Avatar
mechmagcn mechmagcn is offline
Diesel Junky
mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.
Mid-Fifty sells some trim rings for this purpose but I made my own from some .063 aluminum and a piece of an inner tube to seal around the pedals.
Old 08-15-2011, 08:32 AM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Quote:
................................from where?
Old 08-15-2011, 09:02 AM
teardropty's Avatar
I like the fab idea. I have checked out Mid50's stuff but I wanted something a little different. Got a source for the dimmer switch grommet? Thanks!
Old 08-15-2011, 06:32 PM
dongc1's Avatar
Quote:
I think this is where I got them. There are several upholstery supply places that have them.
Dimmer Switch Grommet
Old 08-15-2011, 09:10 PM
Old F1's Avatar
Not sure the grommet will work for a floor mount petal as it arcs and needs a bit more room. Im going to try a model A emergency trim plate for the brake petal, they also make a bigger trim ring for the shifter that might fit the steering column, same supplier.
Ford Model A Emergencey Brake Trim Plate 28,29,30,31 | eBay
Old 08-15-2011, 10:06 PM
49fordpickumup's Avatar
49fordpickumup 49fordpickumup is offline
49fordpickumup is gaining momentum as a positive member of FTE.
Old F-1, that plate reminds me of a house metal light swirch cover that has the opening enlarged and cheap to buy. You could put a piece of inner tube under it and split the inner tube for pedal movement.chuck
Old 08-15-2011, 10:14 PM
dongc1's Avatar
Not sure the grommet will work for a floor mount petal as it arcs and needs a bit more room. I’m going to try a model A emergency trim plate for the brake petal, they also make a bigger trim ring for the shifter that might fit the steering column, same supplier.
My pedals are the original floor mount pedals and the dimmer switch grommet works fine.
Old 08-16-2011, 08:31 AM
teardropty's Avatar
That's what I was looking for. Thanks for the ideas guys.
Old 08-16-2011, 09:58 AM
Old F1's Avatar
Quote:
Originally Posted by 49fordpickumup View Post
, that plate reminds me of a house metal light swirch cover. chuck
.Except smaller and SHINNY!
Old 08-16-2011, 10:47 AM
SFAllison SFAllison is offline
SFAllison is starting off with a positive reputation.
In the past, I have used a soldering iron to create any holes in the carpet for bolts, etc.
Old 08-16-2011, 08:40 PM
old F1, shinny is good. I was thinking of POR-15 and black paint to match black carpet. I was not trying to offend. Just thinking of cheap and availability. chuck
Old 08-16-2011, 10:36 PM
Old F1's Avatar
Chuck, no problem. Some of us are like Ravens or Crows, if it shines we like it! (..and sometimes not too much separates the animal species either . )
Seeking 'carpet pattern' for 1997 e150 Chateau Wagon. dolphinride 1968-2013 Full Size Vans 4 01-24-2015 06:05 AM
New Carpet That Fits TBird Larry 1961 - 1966 F-100 & Larger F-Series Trucks 10 08-30-2014 10:01 PM
SMS Carpet Total Let Down. 79FordBlake 1973 - 1979 F-100 & Larger F-Series Trucks 40 04-10-2010 06:38 PM
Carpet kits for bed rockymtnway Appearance & Dress-Up 5 10-02-2005 05:10 PM
carpet install at steering column imlowr2 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 02-08-2005 06:26 PM
Tags
carpet, pedals
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
