2002 explorer 4.6 engine
Just curious, what happened to the old engine?
Some 4.6L engines will have two knock sensors instead of one like the Explorer uses. Other SOHC engines should work, it just may be hard to get around the wiring issue.
I have read about people putting Mustang 4.6L engines in the Explorer. The cast iron block vs. aluminum does not seem to be an issue.
rowekmr
12-25-2010 08:31 PM
Aerocook
06-21-2010 07:49 PM
MitchPeters
03-15-2004 06:29 PM
2002, 2002fordtruckengines, 46, engine, explore, explorer, ford, knocking, motor, performance, pump, removal, replacement, v8, water
