What do you use to wipe a surface down before painting? - Ford Truck Enthusiasts Forums
Paint & Bodywork SPONSORED BY:
Old 04-02-2003, 10:46 AM
Ken2600 Ken2600 is offline
Ken2600 is starting off with a positive reputation.
I've been using Lacquer Thinner but I see alot of people mention Acetone. Which is better? Should different things be used different times?
Old 04-02-2003, 07:53 PM
Huntsman's Avatar
Huntsman Huntsman is offline
Huntsman is starting off with a positive reputation.
Ken,
I talked to the guys at our local NAPA paint store a while back, when I still thought I would be ready to paint soon, and they suggested a automotive Wax and Grease remover. Wipe it on and while its still wet wipe it off. It dries much slower allowing time to wipe away any residue.
Old 04-04-2003, 03:42 AM
karljay karljay is offline
karljay is starting off with a positive reputation.
I used both before and Acetone seems to dry with no film. I really like the 2nd wipe before it dries method.
take one rag and wipe with acetone, then a second clean dry rag and wipe off the acetone before it air dries.
I also like to keep wiping until I get no streak marks on the surface, usually two to three times.
Some laquer thinners seem to leave an oily residue behind.
Old 04-05-2003, 05:32 PM
Ultra Blue Ultra Blue is offline
Ultra Blue is starting off with a positive reputation.
We use a Grease and Wax remover. I know Autozone sells one thats real cheap in price but the guy that I know uses it says it works good. We use Glasurit and Ardex.
Old 04-06-2003, 08:14 PM
4starcstms 4starcstms is offline
4starcstms is starting off with a positive reputation.
Use wax and grease remover. If you use laquer over primer, can soften and remove if rubbed enough.
I use Dupont Kwik Clean its about 20 bucks for a gallon. PPG, Sherwin Williams, most paint makers offer their own version.
Old 04-06-2003, 09:56 PM
Chas1234 Chas1234 is offline
Chas1234 is starting off with a positive reputation.
My old man worked at a body shop and he uses acid on bear metal before painting ( wash it off with water after and dry it ) it looks pretty good after .
I think it was Muriatic acid (spelling)?
Jon
Old 04-27-2003, 09:48 AM
FordCwazyGuy FordCwazyGuy is offline
FordCwazyGuy is starting off with a positive reputation.
i like the idea of acid on bare metal to remove any rust pitted in metal you can reach with a sander but,wouldnt watering it down afterwards kind of defeat the purpose? i know that if any water gets on any bare metal it will rust in a matter of minutes,just a question
Old 04-27-2003, 08:06 PM
286merc 286merc is offline
286merc is starting off with a positive reputation.
Acid ALWAYS leaves minute salt crystals behind to act as the Energizer Bunny and will eventually ruin your paint. Water alone will not remove Muriatic (diluted Hydrochloric) salts. Finsh with a water & baking soda solution to neutralize the salts.
Muriatic is also VERY rough on your skin.
A MILD phosphoric acid is usually used to etch bare metal so the primer can adhere. Then rinse or follow the instructions on the product.
Get a primer on before the metal flash rusts.
Old 04-30-2003, 10:12 AM
Bondomaniac Bondomaniac is offline
Bondomaniac is starting off with a positive reputation.
Cool What do you use to wipe a surface down before painting?
The easiest way I have found to use wax and grease remover is by using a Sure shot sprayer to spray it on then just wipe it off.
Old 05-11-2003, 04:15 PM
7220driver 7220driver is offline
7220driver is starting off with a positive reputation.
Post What do you use to wipe a surface down before painting?
Check out Eastwood Co. in Pottstown, Pa. They have a product called "Pre" . I've used this after using other methods and still got more off the surface. They specialise in auto body restoration products.
Old 06-08-2003, 02:37 AM
Buckshot14 Buckshot14 is offline
Buckshot14 is starting off with a positive reputation.
At the shop i work for we use wax and grease remover, or ALVIN (alchol and viniger). after that we also wipe over it with a tac rag (sticky paper towel thing that removes any that could be left over....we do all this after the vehicle is in the paint booth..
Michael
headlight switch okiewelder 1961 - 1966 F-100 & Larger F-Series Trucks 9 06-26-2014 05:36 PM
E4OD differences? hav24wheel 1987 - 1996 F150 & Larger F-Series Trucks 7 10-28-2010 08:46 AM
Ranger spring codes? 460 Ranger & B-Series 0 12-02-2009 10:40 PM
Difference - 44T VS 44B Auto trans alchymist Clutch, Transmission, Differential, Axle & Transfer Case 0 10-22-2005 01:44 PM
429 pistons in 460? Wishbone Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 12-27-2002 09:08 AM
Tags
acetone, acid, alcohol, bare, car, kind, metal, muriatic, paint, painting, primer, surface, whipe, wipe, wiping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
