Well, if you know the amps then you just put in any fuse that fits really. You should need the glass fuses and you can find them in about any auto parts store. I have a wiring diagram from my chilton i can post if you want that to see what each fuse runs.
Right, but there are several different lengths, which is what he's asking - all someone with a '77 needs to do is post that page out of their owner's manual, which will tell what type of fuse (AGC, SFE, etc) to use. The fuse panel (and a Chilton's diagram) only shows the amperage.
There is a guy that posted today about fuses so i figured id post his link in here and maybe it can help you out too. He had a 1979 F150 but maybe its the same or you can get an idear from his post.
