Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > EcoBoost (3.5L, 2.0L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
EcoBoost (3.5L, 2.0L) 3.5L Twin Turbo EcoBoost V6 and 2.0L I4 EcoBoost Engines
  #1 (permalink)
Old 08-14-2011, 10:35 AM
diver110 diver110 is offline
Garage is empty, add now
diver110 is starting off with a positive reputation.
Longevity of ecoboost
I would be interested in seeing more discussion of the longevity of the ecoboost. Its gas mileage is not all that great. If the engine, due to the turbo, is only good for 100,000 miles and non-turbo 200,000, ecoboost might not be a good deal. I understand how turbo works generally, but the last turbo I owned was built in the 70's. It may be that a turbo can go as long as any other engine. In any event, I would appreciate feedback in this regard. Thanks.
  #2 (permalink)
Old 08-14-2011, 11:38 AM
Chris Anchor's Avatar
Chris Anchor Chris Anchor is offline
Chris Anchor is gaining momentum as a positive member of FTE.
I can't talk on the Ecoboost directly as I don't own one but as to turbos. Todays turbos are nothing like the 70's or even ten years ago. Tons of advanced designs in their shape and materials have changed the performance and longevity. Chris
__________________
2009 F-150 XLT 4x4 5.4 Regular Cab 8' box 3.73 rear/max tow/8200 lbs GVW/built in controller-One towing/ hauling machine
2012 F-150 XLT 4x4 Ecoboost SuperCrew 6.5 box 3.31 rear A fancy Loaded Sunday go to meeting Truck-Wendy's
  #3 (permalink)
Old 08-14-2011, 01:34 PM
tseekins's Avatar
tseekins tseekins is offline
2011 Ford F-150
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
EcoBoost (3.5L, 2.0L) - Ford Truck Enthusiasts Forums
C'mon down here and visit with us. There's plenty of discussion about the ecoboost engine.
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
  #4 (permalink)
Old 08-14-2011, 05:27 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
Moved to correct forum.
Too soon to tell. i don't see a problem with them lasting in the Taurus, but in a heavy truck ,especially if used for frequent towing, it's hard to say. Only time will tell. Diesel engines last a very long time and are usually turbocharged, but they are also built a lot stronger than a gasoline engine and run in a lower rpm range.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #5 (permalink)
Old 08-15-2011, 06:57 AM
shortride's Avatar
shortride shortride is offline
2010 Ford F-150
shortride is gaining momentum as a positive member of FTE.
Only time will tell about the Ecoboost engines. The Ecoboost engine was built specifically for turbo's. I believe the Ecoboost is a pretty tough little engine. Turbo's use to have a reputation of failure after a few miles because of the heat affect on the bearings in the turbo. There has been some major advances in turbo technology. Everything now depends the most on how well drivers are taking care of there equipment and making sure the oil is changed on a regular schedule. I know nothing of the Ecoboost technology but if I were going to do any mods it would be to increase the size of the inner cooler.
  #6 (permalink)
Old 08-15-2011, 02:14 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
I just saw an article the other day in a mustang rag about a longevity test that ford that was supposed to equal 10 years and 160k. even mentioned something about the baja 1000, but anyways, they tore it apart in front of the press and it showed very little wear. I'll see if i cant find the article...
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
  #7 (permalink)
Old 08-15-2011, 02:18 PM
shortride's Avatar
2010 Ford F-150
A little bit different subject. One of the service tech's returned from some special training at Ford a few weeks ago and told me there was some talk about a twin turbo powered 5.0 Mustang.
  #8 (permalink)
Old 08-15-2011, 06:55 PM
tseekins's Avatar
2011 Ford F-150
Quote:
That would eat a camaro alive!
__________________
Tim
2010 Ford Focus
FTE Guidelines
  #9 (permalink)
Old 08-15-2011, 07:00 PM
shortride's Avatar
2010 Ford F-150
Quote:
It might even give a 6.1 Challenger a run for its money.
Dodge Challenger 6.1 Hemi Stock Dyno Run - YouTube
  #10 (permalink)
Old 08-16-2011, 09:15 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
The 11' NA 5.0l Mustang is a better match to the SRT8 Challenger. A TT EB 5.0l would KILL the Challenger without a doubt.
__________________
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." (Thomas Jefferson)
  #11 (permalink)
Old 08-17-2011, 10:05 AM
OmahaEcoBoost OmahaEcoBoost is offline
OmahaEcoBoost is starting off with a positive reputation.
Quote:
That's what I was thinking. I think the 5.0L Mustang already outruns the Challenger.
Tags
20, 35l, 50l, 60, ecoboost, engine, f150, ford, longetivity, longevity, mods, towing, truck, tt, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
