Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 08-13-2011, 09:36 PM
blackmamba blackmamba is offline
Garage is empty, add now
blackmamba is starting off with a positive reputation.
Cool !!!!Please Help!!!!
For starters I have a 01 hd F150 with 145000 miles on it....SO a little while ago my truck threw a code of P0320 after it started jerking real bad at around 65mph. I went and got it checked and it was a crankshaft sensor or wiring so I changed it and checked the wiring and connector. Reset the code and it went away, until I put about 13 hours on it and it came right back with the same symptoms. So it kicked the same code so I changed yet another sensor and checked the connectors yet again. Reset it and today it just kicked the same thing, this is driving me crazy any help is much needed! thanks
  #2 (permalink)
Old 08-14-2011, 05:25 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
1952 Ford F-1
My Garage
SwOkcOffRoader has a good reputation on FTE.SwOkcOffRoader has a good reputation on FTE.
You need to check the wires to the sensor plug. I've seen em get brittle and break inside, but the insulation looks fine so it's hard to find. Just a possibility.
__________________
Why is there never enough time to do it right the first time, but always enough time to do it again??
....Will work for Rep points....
  #3 (permalink)
Old 08-19-2011, 11:07 AM
Thanks for the tip. it seems that everything was okay, and wouldnt you know it the code cleared itself so here's to hoping the the computer got itself together and it was just a bad glitch.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
