Ecoboost reliable?
#31
The grocery getting vehicles will have problems, but the ones that have fun or tow often will be clean. So go beat on your vehicle! It's a Ford, it can take it!
#32
Basic design does resemble a diesel with forged crank and cross-bolted mains. For the carbon build-up, do what we used to call the "Italian Tune up" Get on the freeway, hammer down and work through the gears occasionally. Driving the kids to school and those short trips to the store are carbon builders in any engine.
#33
#34
#35
The Eco boost has problems with carbon build up on valves, fords TSB. It also states that injector cleaning can not been done do to damage to turbos. Part of the reason is for rich mixture on start up. Under warranty for hesitation, misfire ford techs to check for carbon build up if located recommended to replace heads. So on Eco boost if you have or do de carbon flush say good by to your warranty. How in gods name can ford design a engine that can not be survived for carbon build up. Also from what I understand the 5.0 lt is nothing more the a 4.6 bored
#36
The 5.0 is still a modular engine but it is a Ti-VCT 4 valve. That's a far cry from any 4.6 ever offered in an F150. What's the tsb for carbon on the valves? Last I talked to a field service engineer he told me the Ecoboost was not experiencing carbon buildup on the valves like DI engines from other manufacturers. Of course the BG rep told us all about how bad it was and they were gonna quit running after 60k miles if we didn't use their fuel system treatment through the air intake. I had heard that the rich mixture on start up was causing the black soot on the tail pipes that is so common on the eco boost trucks.
#37
Well if you are getting black soot on the tail pipes that tells you what's going on in the combustion chamber. I don't have the TSB with me but there is information from a ford tech on you tube. This explains what is going on and the TSB explains repair. This information from ford under warranty is to replace heads. Combustion cleaner will over heat the turbos causing failure. If you read about the 5.0LT it explains ford is using the 4.6 block with modified heads.
This may be the thread that you are referring to. It's based on the 2.0L ecoboost, not the 3.5L.
#38
#39
Yes you are correct on the 5.0. Shares same block design as 4.6. I thought you were implying it was strictly a bored/stroked 4.6 which would be selling it extremely short as there's alot more technology to it than the 4.6. The surprise to me would be ford admitting to a problem with the 3.5 eb. They have alot riding on that engine and I'm sure they wanna keep its reputation as clean as possible. I will say that the only engine issues I ever seen personally from the ecoboosts were cac related. It was rare for one to come in with over 100k miles though.
#40
