Brake lights
01-26-2023, 03:44 PM
Brake lights
I have gone thru 3 of the pressure switch on the master cylinder. Does anyone have a better alternative than the oe style?
01-26-2023, 04:38 PM
Are you using something other than DOT3? Have you try a different supplier? I've use the NAPA SL134 and DOT3 without issue.
NAPA SL134
STANDARD MOTOR PRODUCT SLS27
ALLSTAR 76251
01-26-2023, 08:58 PM
.... or, you could run it into a relay so that then the switch would only have to carry just enough current to trip the relay and the relay would switch the rest of the load.
01-27-2023, 02:57 PM
Are you by chance using silicone brake fluid?It loves eating up those pressure switches because most of them are not compatible.
01-29-2023, 05:14 AM
Mine did the same thing. A lot of them do that. I went and got this switch from Summit. Item #rfw-sw68. Don't know why I can't make a link work.
01-29-2023, 07:05 AM
I got a motorcycle style brake switch to replace the unreliable pressure switch, problem solved.
01-29-2023, 08:09 AM
01-29-2023, 08:53 AM
I used the same one as Effietrucker... went thru 3 pressure switches before I gave up...
01-29-2023, 04:21 PM
Harley-Davidson brake light switch # 72023-51D (made in the USA) This was 20+ years ago.
01-29-2023, 04:31 PM
Got a switch from auto zone about 4 years ago still working with silicon brake fluid.
Jonesy0027
03-27-2022 08:42 PM
tvliftcabinet
03-06-2017 11:16 AM
Pappys53
05-18-2013 01:51 AM
Schmitty
15
04-01-2010 01:29 AM
handx2
09-06-2004 12:57 AM
