'51 F4 project
#2161
#2162
#2163
Yeah I was pretty excited to get the right taillight bracket and I'm really jazzed with the "original" look.
#2164
#2165
#2166
I'm using nylocks on it, so I don't think it's going anywhere... Maybe I should insure that part in addition to the truck?
#2167
#2169
Thanks Howard.
Since Ross asked, and since I had only seen them in daylight, I waited until after 5:30 for darkness (I hate Standard time) and asked my obliging wife to video the lights for me. Let's see if I can make this work.
Brake lights, running lights, turn signals, flashers, with headlights...
http://vid285.photobucket.com/albums...4/DSCN2288.mp4
#2170
#2171
I can't back my truck into the garage because the car won't fit next to it if I do. Pulling in forward, the duallies stop before hitting the leg on my compound miter saw stand. I'd have to move over several inches to back in, and then the car would barely fit, but I couldn't get out of it.
#2173
Yes, the script is one of the things I noticed first. I'm not sure why it was illuminated like that, but I thought it was cool. Probably catching light from the lights on the outside of the garage, or maybe from the street light?
I also noticed that I have a problem on the left... When I hit the right signal, the left light went out. I'll need to troubleshoot that.
#2174
Oops! That ain't gonna fit!
I ordered a new gas filler pipe hose to replace the old one in the truck, which I think may actually be original.
The hose in the truck is about 3" long and 2 1/4" ID. I ordered the hose from Classic Haulers item number 1615-SHT, Gas Fill Hose 4". I received a 6" long hose 1615-LNG as they were out of the 4" hoses. The ID is only 1 3/4" but the OD is 2 1/4". So that won't work. I called CH to explain and have not heard back with an answer yet. The item I ordered says it fits 51-72. I guess I should have done more research. My fill pipe is 2 1/4" OD.
Anyway, I ordered a correct ID hose from a hose company, and got it in the mail. 2-1/4" Inch Thermoid 7318 SAE-30r7 Fuel Fill Hose 16731822503
Here are the pics to prove it.
#2175
And now it's in...
I had a chance to do two things to Betsy today. Wow, how weird, I named my truck...
Anyway, the filler pipe hose and the drivers side rear cab mount are replaced.
A special thanks to Jimmy (underthebridgejim) and others who recently posted how to easily install the cab mount using a floor jack for the cab and a bottle jack for pushing the mount arm against the rubber cushion. That made it easy even for me!
And, because someone once said you like pics on this site.... at least I think I read that here somewhere...
Here are the old and new filler pipe hoses. Start with the old.
And the old removed (I sliced it).
And the new installed.
You can see how grungy the clamps were. I cleaned them up.
Then I moved on to the cab mount. I had already checked these a while back to see if the nuts were rusted to the bolts. They weren't, and came out easily. I cleaned them up a bit and installed the mount. Thanks again Jimmy.
Original next to new.
Old worn out.
More old worn out.
Took a shot of the obvious difference in hole spacing.
And installed.
Old worn out.
More old worn out.
And installed.
