'51 F4 project
Old 07-03-2014, 06:22 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Originally Posted by speedyweasel
I still say you need a silhouette of a tree stump on the side of the hood like a WWII aircraft nose.
Something like this?
  #1457
Old 07-04-2014, 09:30 AM
speedyweasel's Avatar
speedyweasel
speedyweasel is offline
Yep. A lot like that.
  #1458
Old 07-13-2014, 01:10 PM
Jolly Roger Joe
Repeat offender...
So I posted this in my thread about "What's missing from my accelerator linkage" but I want to record it here as well. If you already saw it in the other thread, I apologize for wasting your time.
Betsy came to me without a gas pedal. (sounds like the opening of a dime novel). Anyway, I didn't know what the gas pedal linkage was supposed to look like, and the diagram in the Parts Catalog was pretty small. But others on here straightened me out, and Ray (raytasch) actually sent me the needed parts to correct it. You rock Ray!
The existing broken spring was packed with dirt, so it didn't resemble a spring to me. But I sprayed some WD-40 on it and cleaned it up enough to find an end to pull on. So Out with the old and in with the new. The pedal's far enough off the floor to put a new boot on it now.
Here are the before and after pics...
Name:  Gas pedal 2.jpg
Name:  Gas pedal 4.jpg
Name:  Gas pedal 1.jpg
Name:  Gas pedal 3.jpg
Learning something new about this truck every day...
And I took her out for a drive today with my new dog Riley riding shotgun... No pics, my hands were full.
  #1459
Old 07-13-2014, 01:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
I assume now you have about another half of the throttle to lay down some rubber, eh?! You'll be surprised how much noise the boot will eliminate!
  #1460
Old 07-13-2014, 01:32 PM
Jolly Roger Joe
Yeah, I'm looking for more tree stumps to pull with all that extra pedal! Too bad they closed down the local drag strip...
  #1461
Old 07-13-2014, 01:48 PM
Jolly Roger Joe
Looking for suggestions
Does anyone have a suggestion on how to repair the "cardboard" firewall cover in my truck? I realize it's 63 years old and probably rotting. But do I have to replace the whole thing or can it be repaired somehow?
This is the only section that's damaged. I'm wondering if the stock rubber floor mat will cover this area...
EDIT: OK, I looked through all eight of my catalogs, and none of them show the original firewall cover I've got. Everything is fiberglass or ABS. I also looked at the online catalogs and included Chuck's Trucks with the same results. So I guess no one sells the original...
  #1462
Old 08-03-2014, 03:47 PM
Jolly Roger Joe
Classic Haulers rocks!
I ordered the hood trim points from Classic Haulers for Fathers Day. They were back-ordered for over a month, but finally arrived yesterday. Candi was very helpful filling the back-order.
No other place I get parts has a personalized, hand-written "thank you" on the invoice.
And then there's the Tootsie Rolls...
Name:  Tootsie Rolls.jpg
I didn't have any bolts short enough to mount them to the hood, so I made some. Much easier to make them shorter than to make them longer.
Name:  Hood points 1.jpg
They look good even on my crummy paint job.
Name:  Hood points 3.jpg
Now if I could just figure out how to get the other ss strips mounted, I'd be doing good. I have the correct pieces and mounting clips, but I can't get them on. The clips won't pop through the holes.
  #1463
Old 08-03-2014, 04:02 PM
Harrier's Avatar
Harrier
Harrier is offline
Those look sharp, Joe!
For the other strips, are you holding you tongue in the left side or right side of your mouth?
  #1464
Old 08-03-2014, 04:19 PM
Jolly Roger Joe
Pretty sure it was the left side while working on the drivers side and the right side while working on the passenger side.
Do I have that backwards?
  #1465
Old 08-03-2014, 05:48 PM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Just don't grind your teeth when you crank on a torque wrench!
  #1466
Old 08-03-2014, 08:01 PM
Jolly Roger Joe
You were right. I wasn't holding my mouth just right.
I stopped grinding my teeth! It worked!
Thanks guys! Once again, FTE comes through!
Name:  Hood trim 3.jpg
  #1467
Old 08-03-2014, 09:25 PM
Harrier's Avatar
Harrier
Harrier is offline
Awesome!! My next suggestion would have been for you to tell you wife how difficult it was, then have her go to the garage and watch you do it. The clips would almost fall into place with her watching. Betsy would do that to you just so see your wife give you "that look" and walk off shaking her head.
  #1468
Old 08-03-2014, 09:33 PM
The Horvaths
Reps to Harrier! Found the key, he did!
  #1469
Old 08-03-2014, 10:00 PM
Jolly Roger Joe
Actually, my son came over and helped me with part of the installation. But it was not going well, so we quit. He had the idea that if the clips were installed first and we could loosen them, we could slide the trim over them into place. But we couldn't make them loose enough to slide the trim freely.
Then I improvised using his idea and some cable ties. That loosened up the clips enough to slide on the trim.
  #1470
Old 08-03-2014, 10:02 PM
Jolly Roger Joe
She offered to help me if I needed it. But I hadn't yet figured out how to do it.
Yes, he gets my vote also!
Quick Reply: '51 F4 project
