'51 F4 project
#1306
#1307
I can see from the parts catalog drawing that this is a tapered fit on the ball. But I can't understand why it won't release when I smack it with a hammer.
Pages from Illustrations Catalog_Searchable.pdf
#1308
#1310
#1311
So, after getting more info about what I'm trying to do from Ross, I now have the spindles removed along with the drag link. The old king pins will basically fall through the old bushings, so they were definitely worn.
I checked the components of the drag link and there is no noticeable wear to the ***** on the steering arm or the spindle arm stud. But the whole drag link does need a good cleaning, just like Ross told me it would.
I think when I lubed the truck I must have missed some of the grease zerks in the steering components, as the grease is all old and I don't see any of my new grease in any part of it.
And now, after seeing the drag link disassembled, I think it may not have been adjusted properly, since the rear plug was not flush with the end as was the front plug. Maybe there was slop in there as a result. I'll definitely check the adjustment when I put it back together.
One last pic of all the dirty stuff before it's off to the machine shop.
#1312
#1313
Well, I'll see about that extra mph. Maybe all the way up to 47?
Dropped off the spindles, pins and bushings at the machine shop. He said they'd be done this afternoon or Monday.
I have a little time now to clean up all the other parts and prepare for assembly.
Thanks everyone for your suggestions. A special thanks to Ross.
#1314
I got my spindles back from the machine shop today. I was looking at the drag link, which I took apart to clean out all the old grease and check for wear.
So, I'm now thinking about putting it back together, and I looked in the Shop Manual for a pic. This is what's shown. My question is this:
Is this the correct order for the ball seats and springs for both ends of the drag link? They're in the same order left to right except for the plugs, instead of opposite each other as I thought...
Just checking so I don't screw it up...
#1315
#1317
Just a before and after pic of the spindles, and drag link. But I also wanted to mention the shop that pressed and reamed my bushings. They did a great job:
Karl's Auto Machine Shop in Corona, CA. Karl also told me he works on flatheads, so I'll definitely take mine there if it ever needs work.
Karl
Before. That pin on the right is the one I had such a hard time getting out. Notice the black scoring...
After
And, it's obvious the two ends of the drag link are different. But I didn't notice the difference until after I started cleaning it.
Karl
After
#1318
#1319
Started working on it at 7:30 this morning and just got the shop cleaned up a few minutes ago. Besides cleaning all the parts to paint, I had some small ridges to take out of the axle holes so the new pins would fit, but now Betsy's back together. I'm anxious to see if the steering wander is gone. Besides the new king pins, I adjusted the drag link according to the Shop Manual, and it's tighter than the PO had it. There's no wear in it's parts or to the ***** on the spindle arm or steering arm. I greased everything up good, repacked the wheel bearings (which I just did a few weeks ago).
I'm gonna shower and take her out to dinner, so to speak.
#1320
OK, dinner was good. Betsy steers better. I don't have to fight the wheel to keep her in a straight line. I suppose it was a combination of the king pins and the drag link adjustment. Whatever, I don't have to fight to keep her in a lane.
I suppose, since I had the tie rod off to replace the king pins and to repaint it, I should recheck the toe-in adjustment. But I'm happy with the steering now.
And now for some frosty beverages!
