'51 F4 project - Page 98 - Ford Truck Enthusiasts Forums
'51 F4 project
  #1456
Old 07-02-2014, 10:09 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Originally Posted by speedyweasel View Post
I still say you need a silhouette of a tree stump on the side of the hood like a WWII aircraft nose.
Maybe I should have a decal made...
  #1457
Old 07-03-2014, 07:22 PM
Just another Joe
Something like this?
  #1458
Old 07-04-2014, 10:30 AM
speedyweasel's Avatar
speedyweasel speedyweasel is online now
speedyweasel is gaining momentum as a positive member of FTE.
Yep. A lot like that.
  #1459
Old 07-13-2014, 02:10 PM
Just another Joe
Repeat offender...
So I posted this in my thread about "What's missing from my accelerator linkage" but I want to record it here as well. If you already saw it in the other thread, I apologize for wasting your time.
Betsy came to me without a gas pedal. (sounds like the opening of a dime novel). Anyway, I didn't know what the gas pedal linkage was supposed to look like, and the diagram in the Parts Catalog was pretty small. But others on here straightened me out, and Ray (raytasch) actually sent me the needed parts to correct it. You rock Ray!
The existing broken spring was packed with dirt, so it didn't resemble a spring to me. But I sprayed some WD-40 on it and cleaned it up enough to find an end to pull on. So Out with the old and in with the new. The pedal's far enough off the floor to put a new boot on it now.
Here are the before and after pics...
Name:  Gas pedal 2.jpg
Name:  Gas pedal 4.jpg
Name:  Gas pedal 1.jpg
Name:  Gas pedal 3.jpg
Learning something new about this truck every day...
And I took her out for a drive today with my new dog Riley riding shotgun... No pics, my hands were full.
  #1460
Old 07-13-2014, 02:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I assume now you have about another half of the throttle to lay down some rubber, eh?! You'll be surprised how much noise the boot will eliminate!
  #1461
Old 07-13-2014, 02:32 PM
Just another Joe
Quote:
Yeah, I'm looking for more tree stumps to pull with all that extra pedal! Too bad they closed down the local drag strip...
  #1462
Old 07-13-2014, 02:48 PM
Just another Joe
Looking for suggestions
Does anyone have a suggestion on how to repair the "cardboard" firewall cover in my truck? I realize it's 63 years old and probably rotting. But do I have to replace the whole thing or can it be repaired somehow?
This is the only section that's damaged. I'm wondering if the stock rubber floor mat will cover this area...
EDIT: OK, I looked through all eight of my catalogs, and none of them show the original firewall cover I've got. Everything is fiberglass or ABS. I also looked at the online catalogs and included Chuck's Trucks with the same results. So I guess no one sells the original...
  #1463
Old 08-03-2014, 04:47 PM
Just another Joe
Classic Haulers rocks!
I ordered the hood trim points from Classic Haulers for Fathers Day. They were back-ordered for over a month, but finally arrived yesterday. Candi was very helpful filling the back-order.
No other place I get parts has a personalized, hand-written "thank you" on the invoice.
And then there's the Tootsie Rolls...
Name:  Tootsie Rolls.jpg
I didn't have any bolts short enough to mount them to the hood, so I made some. Much easier to make them shorter than to make them longer.
Name:  Hood points 1.jpg
They look good even on my crummy paint job.
Name:  Hood points 3.jpg
Now if I could just figure out how to get the other ss strips mounted, I'd be doing good. I have the correct pieces and mounting clips, but I can't get them on. The clips won't pop through the holes.
  #1464
Old 08-03-2014, 05:02 PM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Those look sharp, Joe!
For the other strips, are you holding you tongue in the left side or right side of your mouth?
  #1465
Old 08-03-2014, 05:19 PM
Just another Joe
Pretty sure it was the left side while working on the drivers side and the right side while working on the passenger side.
Do I have that backwards?
  #1466
Old 08-03-2014, 06:48 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Just don't grind your teeth when you crank on a torque wrench!
  #1467
Old 08-03-2014, 09:01 PM
Just another Joe
You were right. I wasn't holding my mouth just right.
Quote:
I stopped grinding my teeth! It worked!
Thanks guys! Once again, FTE comes through!
Name:  Hood trim 3.jpg
  #1468
Old 08-03-2014, 10:25 PM
Harrier's Avatar
Awesome!! My next suggestion would have been for you to tell you wife how difficult it was, then have her go to the garage and watch you do it. The clips would almost fall into place with her watching. Betsy would do that to you just so see your wife give you "that look" and walk off shaking her head.
  #1469
Old 08-03-2014, 10:33 PM
Reps to Harrier! Found the key, he did!
  #1470
Old 08-03-2014, 11:00 PM
Just another Joe
Actually, my son came over and helped me with part of the installation. But it was not going well, so we quit. He had the idea that if the clips were installed first and we could loosen them, we could slide the trim over them into place. But we couldn't make them loose enough to slide the trim freely.
Then I improvised using his idea and some cable ties. That loosened up the clips enough to slide on the trim.
1960 f350 express bed (9ft) 57to60fords 1957 - 1960 F100 & Larger F-Series Trucks 5 12-21-2012 11:01 AM
test pic scmbmw User Gallery & Picture Display 1 09-29-2012 02:32 PM
Hot August Nights pics hotfalcoon 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 08-20-2011 07:54 PM
nose dive 503racing Offroad & 4x4 30 03-11-2011 04:42 PM
Carburetor questions rodeojunky 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-08-2010 06:54 PM
Tags
1951, 51, f4, ford, horn, motor, nyc, parts, signals, towing, truck, trucks, turn, wheels, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
