'51 F4 project - Page 96 - Ford Truck Enthusiasts Forums
'51 F4 project
  #1426
Old 06-05-2014, 01:39 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Originally Posted by 38 coupe View Post
Now that I look more at the pictures of your generator, I think the whole generator is 1955. The back of the armature is smaller diameter to fit into the rear bearing; armatures going into bushings are larger diameter. The front and back plates include mounting ears. Originally H six cylinders used the same generator as the 8BA V8s. There was a separate bracket with a strap that held the original generator. Check out page 139 of the illustration section of the 48-56 Ford Truck Parts book (page 974 in the PDF). You can see the bracket and generator in this picture I found on Photobucket:
Interesting observation. I, too, thought the only difference in the generator could not possibly be just the back plate because the OD of the rear of the armature has to match the size of the bearing, or bushing. In the stock generator for 51, the rear bushing supports the armature. In my generator, the rear of the armature is supported by a bearing. After I discovered I have a later model rear plate with different brushes and a bearing instead of a bushing, I wondered if the generator was original. So what you say makes sense. I do not have a "mounting" band around my generator. But I have three bolts to secure it to the engine.
  #1427
Old 06-07-2014, 04:34 PM
Just another Joe
Running again!
I got the generator installed today. I did not have to polarize it. I also forgot to take pics of it while disassembled after I cleaned it up.
And, of course, I scratched the paint putting it back in.
Here's a few after shots:
Here's a video that shows how it wobbled before (technical term). It looks like the belt is actually jumping...
New Fan Video by JollyRogerJoe | Photobucket
And here's how it looks now.
Generator Rebuilt Video by JollyRogerJoe | Photobucket
  #1428
Old 06-15-2014, 04:32 PM
Just another Joe
Was it something I said?
Kind of surprised no one has commented on my before and after videos after the generator went back in.
I mean, come on guys... it's a video.
  #1429
Old 06-15-2014, 04:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
It appears to be the same video, twice? I can't see a difference??
  #1430
Old 06-15-2014, 05:24 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Quote:
Originally Posted by Jolly Roger Joe View Post
Ray, have you driven Blue yet? Just wondering how much different the ride is with these shocks compared to normal.
Or are you doing this to Blue because Missy Green rides better?
OK, Joe, we'll go back in your thread a slight bit but on topic.
I would estimate I've driven [B]Blue[/B] well over a thousand miles total, several hundred at interstate legal speeds. I am extremely satisfied with the way she rides, drives stops and handles. Remember, no PS or PB.
I am running 225/70 R19.5s on the front and LT235/85 R16s on the rear, just about equal height. I've experimented with tire pressures while driving at lower speeds and am down to running 40 psi in the front and 35 psi in the rears. On the fronts, I've painted stripes across the tire and seem to be getting equal deterioration of the paint across the ribs. There is no squirm or mushy feeling. On the rears, I am down to 35 psi and the tires are still riding on the center three ribs. I may try going down to 30 psi on the rear and see what happens, if it will come down and ride on all five ribs. None of the tires are running hot. When I reduced the pressures in the tires it got rid of the bone jarring rough ride.
There are no vibrations from the front end, even at road speed. I attribute this to a total rebuild, a good balance job and the installation of shocks.
I would guess there will be naysayers who will say I am crazy for running such low pressures. Of course, I would never attempt to run these pressures and haul any load. Did I say I am pleased with the way she drives M. G. may still ride softer.
I doubt if the shocks make any significant difference at 45 mph or slower.
  #1431
Old 06-15-2014, 11:32 PM
toby tough's Avatar
toby tough toby tough is offline
toby tough has a good reputation on FTE.toby tough has a good reputation on FTE.
Well Joe I just watched both of your videos and I could tell the difference. Especially the after shot from the good side. Good job.
  #1432
Old 06-15-2014, 11:45 PM
ALBUQ F-1's Avatar
postin' fool
LOL, I downloaded the same vid twice. Now I see the difference, much smoother!
  #1433
Old 06-16-2014, 01:20 AM
Just another Joe
Quote:
I would estimate I've driven [B]Blue[/b] well over a thousand miles total, several hundred at interstate legal speeds. I am extremely satisfied with the way she rides, drives stops and handles. Remember, no PS or PB.
Thanks for the follow up Ray. I'm going to try lowering the tire pressure more to see if the bouncing is reduced.
And I never thought about the painted stripe to see if they're riding flat.
  #1434
Old 06-16-2014, 01:25 AM
Just another Joe
Quote:
Quote:
One of the reasons I wanted you guys to see the smooth generator operation is so you can check out the mounting bracket, which I think is different from every other 226 mount I've seen. I don't have the big "clamp" mount like what's shown in the parts book. And the adjustment bracket on top works, but is attached from the back instead of the front, which is where it should be bolted.
So back to what was said earlier, I think this is a later generator that was retrofitted to my engine.
What do you guys with 6 cylinder trucks think?
  #1435
Old 06-16-2014, 08:54 PM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 has a good reputation on FTE.Marauder2004 has a good reputation on FTE.
Nice job on the rebuild Joe!
  #1436
Old 06-17-2014, 10:11 AM
Just another Joe
Quote:
Thanks Marauder.
  #1437
Old 06-22-2014, 04:55 PM
Just another Joe
Phone mount
I have been driving Betsy with my phone sitting in the ashtray running the app "Android Speedometer" so I have an idea how slow I'm going (notice I didn't say how "fast"). My speedometer is way off, so when I'm doing 35, my speedometer says I'm doing 20...
Anyway, for Fathers Day my daughter got me a Nite Ize Steelie which I stuck in the middle of the dash. The mount location allows me to see the phone display easily and plug into the power socket (thanks again Bob) without having the cord interfere with anything (like the shifter).
And since I uploaded all my iTunes to the Google cloud, I can use my phone as a speedometer AND a sound system.
Here's a few pics...
The steel mount stuck to the dash
The phone has a very strong, small, concave magnet stuck on the back. The concave shape allows it to be positioned anywhere on the steel ball.
This blurry shot shows the power cord plugged in.
And the view from the driver's seat. I'm going really slowly inside my garage...
I also have some portable speakers which I will try later to enhance the music from the phone.
  #1438
Old 06-22-2014, 06:35 PM
toby tough's Avatar
Hey Joe,I got a little round speaker from Wallyworld for about 20 bucks that I use for my laptop.You could get one and have some good sound from it. You can get a cord to fit your phone .It has it's own rechargeable battery too. I think it's a IHOME model ihm 59. Don't mean to be knockin' yours but this one is pretty good.
  #1439
Old 06-22-2014, 06:39 PM
Just another Joe
Yeah Toby, that's a great idea!
That's what I already have hooked to my laptop, and what I mentioned earlier when I said "I also have some portable speakers which I will try later to enhance the music from the phone."
I tried them with my phone here in the house, and the music sounded just like it was coming off my computer.
  #1440
Old 06-22-2014, 06:59 PM
Just another Joe
Hey, have you tried these in your truck? I know they have magnetic bases, but I don't yet know if those are strong enough to hold it on the dash.
1952 Ford F-8 pilot31 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 08-04-2016 09:41 PM
Daytona 2012 firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-28-2012 10:27 AM
Help with possible engine/tranny choices HkyswiM 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 04-10-2012 02:27 PM
1995 F350 7.5L - Can Anyone Identify This Part? cougarman001 1987 - 1996 F150 & Larger F-Series Trucks 5 01-22-2012 08:01 AM
What Turbo is this? Rubidon 1999 - 2003 7.3L Power Stroke Diesel 10 06-28-2010 09:45 PM
Tags
1951, 51, f4, ford, horn, motor, nyc, parts, signals, towing, truck, trucks, turn, wheels, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
