'51 F4 project - Page 95 - Ford Truck Enthusiasts Forums
'51 F4 project
  #1411
Old 06-02-2014, 10:10 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Originally Posted by GB SISSON View Post
My hat's off to you for waiting for the paint to dry before handling it. I usually leave finger prints as I get too itchy to try my 'new part'. I have always enjoyed this build!
Thanks you, sir!
It has at times been a rant or rambling, but hopefully there's a bit of helpful info in here for guys like me that don't know what they're doing.
I'm fairly certain that if I had gotten this truck and had not found FTE, it would be someone else's truck already.
  #1412
Old 06-02-2014, 04:04 PM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
Quote:
Originally Posted by The Horvaths View Post
Worse comes to worse, you can always re-polarize it. However, it should not need it. When you first start the truck, keep an eye on the charge gauge just in case. Am I paranoid or experienced?
It will prolly need it. Most I have ever seen do after being hit or dropped
or rebuilt.
  #1413
Old 06-02-2014, 04:11 PM
Just another Joe
Quote:
or rebuilt.
I had to polarize the gen when I first got the truck as the PO had it hooked up negative ground and I switched it back.
  #1414
Old 06-02-2014, 05:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I think it's usually needed after a rebuild because they use a growler on the coils and armature, so it loses its residual magnetism.
  #1415
Old 06-02-2014, 06:05 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Quote:
Ditto, I don't think you did anything to cause it to lose its polarization. Although, if your luck is like mine Murphy might have visited in the night.....LOL
Bobby
  #1416
Old 06-03-2014, 12:01 AM
Just another Joe
Quote:
Bobby
Well, it's easy enough to check and it's easy to polarize, so I'm not worried about that. Yet...
Hey! the smilies are back. They haven't worked for me in a while. And I bet some of you were glad.
I just got to my room in Richland, WA. It's been a long day. Maybe I'll get a chance to see Wayne while I'm here.
  #1417
Old 06-03-2014, 06:52 AM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Thumbs up
  #1418
Old 06-03-2014, 06:33 PM
Just another Joe
I've been thinking about this bent pulley on my generator for a while now. Ray said the sticker by the terminals looked like a rebuild sticker, and it probably is but I can't read it.
So the generator was rebuilt at some time in the past, and when that happened, they used the newer style '56 onward rear plate with the brushes attached. Thanks for that info 38 Coupe! That may be the only thing they did to it.
I bet after it was rebuilt, whoever was putting it back in the truck dropped it and bent the pulley. But, it worked, so they never tried to fix it.
Looking at the video I took of the new fan (thanks Ross) installed shows the wobble at the generator.
New Fan Video by JollyRogerJoe | Photobucket
  #1419
Old 06-03-2014, 11:40 PM
Just another Joe
On a side note... I was able to hook up with Wayne (52 Merc) tonight for a fine dinner. This kind of opportunity is one of the few things I like about traveling for a living. And that will be ending in just under 4 months. Thanks again Wayne!
Then the rest of you guys better watch out, because after I'm retired, I plan to look up a bunch more of you "old Ford" guys while traveling around the rest of the country.
On that note, my wife thinks we ought to get a big truck and car trailer to drag Betsy around the country. I'm one lucky guy...
  #1420
Old 06-04-2014, 10:51 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Thank you, Joe, for a fun evening and great company. Hope you get to drop by again soon. Don't forget to take the high road on the way home. It's worth the drive.
http://www.columbiariverhighway.com/...er_highway.pdf
Historic Columbia River Highway
  #1421
Old 06-04-2014, 03:57 PM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
The picture brings back good memories of flying in a small plane up the Columbia River to the tri cities area on a beautiful many years ago.
  #1422
Old 06-04-2014, 05:41 PM
ALBUQ F-1's Avatar
postin' fool
Is that Multnomah Falls? I've never seen it when it wasn't raining...
  #1423
Old 06-04-2014, 06:06 PM
52 Merc's Avatar
Historic US 30 is the original road that was built through the Columbia Gorge, about 100 years ago, for travelers heading to Portland. A preserved section of it (in the map, linked above) goes by many beautiful water falls, including Multnomah. It's one of the most incredible drives anywhere in the world. Highly recommended for anyone coming through the area to take the extra hour and experience it. Joe and I discussed it at dinner last night. This time of the year with the spring runoff at it's peak, all of the falls will be spectacular.
  #1424
Old 06-04-2014, 07:03 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Now that I look more at the pictures of your generator, I think the whole generator is 1955. The back of the armature is smaller diameter to fit into the rear bearing; armatures going into bushings are larger diameter. The front and back plates include mounting ears. Originally H six cylinders used the same generator as the 8BA V8s. There was a separate bracket with a strap that held the original generator. Check out page 139 of the illustration section of the 48-56 Ford Truck Parts book (page 974 in the PDF). You can see the bracket and generator in this picture I found on Photobucket:
  #1425
Old 06-04-2014, 08:22 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Stopped on at Multnomah Falls at least twice times on our trips back home from Wenatchee, WA. Last time we drove the narrow road (maybe it was US 30) and saw several other falls in the same area. I agree with Wayne, that drive is beautiful! A hike to the top of Multnomah is breathtaking, but we never had the time to do it.
1952 Ford F-8 pilot31 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 08-04-2016 09:41 PM
Daytona 2012 firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-28-2012 10:27 AM
Hot August Nights pics hotfalcoon 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 08-20-2011 07:54 PM
1951 Ford F4 - Picking it up today. speedyweasel 1948 - 1956 F1, F100 & Larger F-Series Trucks 52 08-13-2011 07:20 PM
4R100 rebuild in progress nissandoc 1999 - 2003 7.3L Power Stroke Diesel 56 09-28-2009 08:04 PM
Tags
1951, 51, f4, ford, horn, motor, nyc, parts, signals, towing, truck, trucks, turn, wheels, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
