'51 F4 project - Page 90 - Ford Truck Enthusiasts Forums
'51 F4 project
  #1336
Old 05-01-2014, 01:10 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
LOL, I caught my mistake and edited it out, but not before you "captured" it. It was the 215's / 223's that had ears, not the flat-6's.
  #1337
Old 05-01-2014, 01:29 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is online now
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Originally Posted by ALBUQ F-1 View Post
AFAIK all internals are the same and both are bearing front/bushing rear.
Okay, so the "Typical" drawing I loaded shows a rear bearing, but that's actually for a '56 or newer generator.
I need the front bearing and rear bushing.
EDIT: I looked up the part numbers in the Text Catalog and now I see that I need a 8BA-10094 bearing and a 78-10128 bushing.
Thanks for your replies, y'all.
  #1338
Old 05-01-2014, 10:04 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Quote:
I have the same exact drawing in my original pre '55 catalog. Engineering number P-1829 in lower right corner. But reading the text, I, too, see that the correct, original generator used a bushing. I guess we should hope it hasn't been swapped for something else.
  #1339
Old 05-01-2014, 10:28 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
What about switching out to a 6v pos ground alternator?? When I needed to have the generator rebuilt in the 52, the cost of a rebuild and a new 6v pos alternator was about the same. Granted it won't look original and you'd have to fab a mounting bracket, but you'll have better charging.
  #1340
Old 05-01-2014, 12:01 PM
Just another Joe
Quote:
Pretty sure it's the original generator. It looks that way, anyway.
Quote:
Well, it's about $12 for the bushing and the bearing. Plus $10 for brushes. I don't know yet if I need brushes but since I'll have it apart... So $22 plus shipping. I have no problem charging with the current (see what I did there) generator, so I think I'll keep it stock and be cheap, as usual.
Do places like Napa or AutoZone or O'Reilly's carry these parts? That would save on shipping.
  #1341
Old 05-01-2014, 01:36 PM
ALBUQ F-1's Avatar
postin' fool
Looks like it, although I'm suspicious of the bearing, take your calipers along...
Gosh, no question where the bearing comes from... NAPA shows another one in their upscale line I'd be inclined to get, even at 2x the price.
  #1342
Old 05-01-2014, 02:50 PM
Just another Joe
Thanks for looking that up Ross.
I see now why I couldn't find these. I looked on the NAPA website for generator / bearings but found nothing for my truck. I should have searched without listing my vehicle. I'm going to see if they have the bushing as well...
Well, well, well. I couldn't find any specs on the bushing from NAPA or in the Text Catalog. So I went looking elsewhere. RockAuto.com has the brushes, bushing and bearing for $11.09 with $5.12 shipping. For $16.21, I ordered them from RockAuto.
So now I have a Betsy project for my May vacation in three weeks.
  #1343
Old 05-01-2014, 03:08 PM
speedyweasel's Avatar
speedyweasel speedyweasel is offline
speedyweasel is gaining momentum as a positive member of FTE.
RockAuto never ceases to amaze with some of the parts they stock. It's just "an online retailer" but they seem to have some truly obscure parts. Summit has gotten loads better in recent years, too. They've deviated from the 'strictly racing' mindset into a lot more areas. I nabbed some liquid-filled engine mounts for my Cummins 4BT conversion from Summit -- at 1/2 the price of the O'Reilly & NAPA and they got here in about 28 hours. Not bad.
Those kingpins look pretty now that they're all churched up again!
  #1344
Old 05-01-2014, 03:14 PM
Just another Joe
Quote:
Yes, and like the tranny that's "all churched up again", no one will ever see them.
But I drove her to Costco this morning to get gas ($4.02/gallon) and I'm quite pleased with the steering now. The only problem is the steering wheel is way off center. But I can deal with that.
I sure wish the roads had less craters though. Man, what a bouncy ride!
  #1345
Old 05-01-2014, 05:48 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Y
Have we discussed tire pressure. Betsy will do just fine running tire pressure way less that recommended. Takes a lot of the road shock out.
How about front shocks? The 1956 shocks and brackets will work.
  #1346
Old 05-01-2014, 06:01 PM
Just another Joe
I have the tires at 40 psi all around. No shocks on an F4, front or rear. The max rating is 90 psi. And the bad bounce comes from the rear with no weight back there. I try not to drive over 30 mph and slow down if I know a crater is coming. Did I mention I never noticed these "craters" in my car?
But I do have these overload springs which I'm pretty sure never get used nowadays. I can't imagine how much weight would have to be on the bed for the upper springs to be used. Maybe a ton, since she's a 1 ton?
I'm thinking one of these days I'm going to need to refurb the springs. And I'm really not looking forward to that. I like the ride height, so I don't want to remove leaves. But I bet they're all rusted together. The PO just painted them all black when he painted the frame.
It's worse than riding a hardtail Harley. I hit a bump today and the bounce started to pull my pants down from friction on the seat back. Thank goodness for seat belts!
  #1347
Old 05-01-2014, 06:12 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Joe,
Its amazing the differences in springs between todays 1 ton trucks and older trucks.
A few years ago I was driving dad's 74 Dodge 1 ton. I think the only suspension is in the seat....LOL. Its like riding in an old buckboard.
Maybe you could add some weight to the truck bed. Maybe do something like find some old wooden barrels and fill them full of sand or something like that
Bobby
  #1348
Old 05-01-2014, 07:01 PM
ALBUQ F-1's Avatar
postin' fool
You've got near a half-ton of unsprung weight back there, no easy solution.
  #1349
Old 05-01-2014, 07:06 PM
Just another Joe
And it probably will last forever if I don't do something stupid.
Heck, it's already 63 or 64 years old. But it sometimes feels like it's leaving the ground even when I'm not going fast. And parking lot speed bumps are deadly...
I just don't want to break anything.
  #1350
Old 05-01-2014, 07:12 PM
ALBUQ F-1's Avatar
postin' fool
You can get rid of the aux springs, it will reduce the unsprung weight maybe a hundred lbs, but I really doubt they are in play as far as spring rate. Shocks up front would really help, as Ray suggested. It helps stop the rocking-horse.
1952 Ford F-8 pilot31 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 08-04-2016 09:41 PM
Daytona 2012 firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-28-2012 10:27 AM
Help with possible engine/tranny choices HkyswiM 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 04-10-2012 02:27 PM
1995 F350 7.5L - Can Anyone Identify This Part? cougarman001 1987 - 1996 F150 & Larger F-Series Trucks 5 01-22-2012 08:01 AM
What Turbo is this? Rubidon 1999 - 2003 7.3L Power Stroke Diesel 10 06-28-2010 09:45 PM
Tags
1951, 51, f4, ford, horn, motor, nyc, parts, signals, towing, truck, trucks, turn, wheels, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
