'51 F4 project - Page 89 - Ford Truck Enthusiasts Forums
'51 F4 project
  #1321
Old 04-29-2014, 10:20 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
OK, dinner was good. Betsy steers better. I don't have to fight the wheel to keep her in a straight line. I suppose it was a combination of the king pins and the drag link adjustment. Whatever, I don't have to fight to keep her in a lane.
I suppose, since I had the tie rod off to replace the king pins and to repaint it, I should recheck the toe-in adjustment. But I'm happy with the steering now.
And now for some frosty beverages!
  #1322
Old 04-29-2014, 10:57 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Hey Joe, how long until your retirement? I need the front end in the 52 redone. Hotel and food will be covered. TEE HEE
  #1323
Old 04-30-2014, 06:30 AM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Careful, 51Panelman. Those Julie references could get somebody "banned.. ..for life."
Why can't we all just get along?
Anyway, Joe, when I go to disassemble a front end component, I count threads and write it down. Then it goes back together with the same amount of threads sticking out. Assuming it was ever right, that will get it close enough that I can fine-align from there.
Toe-in can be checked with a tape measure after slowly driving a straight line on level ground. Measure to like points on good tire tread. Having an assistant is pretty much mandatory. I have used this method and then driven to an alignment shop (remember them?) and the toe-in was within spec.
  #1324
Old 04-30-2014, 10:53 AM
Just another Joe
Quote:
Ilya, 156 days. But who's counting? One thing I've come to appreciate about the F4... its ground clearance when working underneath. But the downside is the tires/wheels are so danged heavy. Wish I had 22.5s, glad I don't.
Yeah Jeremy, that's how I set the toe-in last time after I replaced the tie rod and ends. I don't think I let the tie rod ends rotate too much while I had it off this week. But I will check it again. It's a pretty tight spec at only 1/16". And I've read on here somewhere that a little greater toe-in may be a good thing.
And I had to remove the tie rod completely to do the king pins. So I may not have changed the toe-in anyway.
  #1325
Old 04-30-2014, 11:10 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
My truck runs straight as an arrow with as close to -0- toe-in as I can get. I have radials, do you? The spec is actually 0 to 1/16", i.e., no toe-out.
  #1326
Old 04-30-2014, 11:13 AM
Just another Joe
Quote:
Yes, I have 8R19.5s on the front. So I will try to zero it out. Pretty sure I set it for 1/16 last time.
  #1327
Old 04-30-2014, 12:50 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
One of the things that I have learned when setting toe-in for all of the old cars and trucks around here....the wheels and tires aren't usually perfect. They all seem to have a little run-out.
One way to deal with that is to measure the distance between some point on the wheel, then mark that spot. For the first measurement,that spot should be towards the front of the truck. Be sure to mark both wheels. Now rotate the wheels until those spots are towards the "back" of the truck and measure between those two spots again. It is best with the weight of the truck on the wheels.
Just a thought.
Dan
  #1328
Old 04-30-2014, 08:39 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Glad to hear that you're back together and rolling again. Especially nice to hear that your hard work paid off and it really drives nice.
I've set the toe numerous times with a tape measure. Heck, I've even gone as far as setting the camber using a framing square and some mathematics. There's just no way of measuring caster in the driveway with basic tools but you can get everything else pretty danged close.
These trucks can take quite a bit of toe in. Not enough and you can get the "death wobble"
Go enjoy your frosty beverage(s), you earned it
Bobby
  #1329
Old 04-30-2014, 10:29 PM
Just another Joe
And on to the next project...
Thanks Bobby.
I am going to rebuild my generator. It's recharging the battery okay. But I think the old fan belt was too tight when I got the truck. I notice the pulley slightly wobbles, so I figure it's a good idea to do a little preventive maintenance before I get stuck somewhere. Like up the creek. Without a paddle.
So, I researched the Shop Manual and the Parts books. There is no drawing in the Shop Manual of a generator for a 6 cylinder. The one shown in Fig. 12 on page 253 is for V8. But they were all 6 volts in those days, so I'm guessing the drawing shows the mount for the V8 which differs from the 6 cyl. In that figure there is no rear bushing or bearing shown.
In the Illustrations Catalog, there is a "Typical" Generator on page 309 which shows 10094 front bearing and 10095 rear bearing.
Name:  Pages from Illustrations Catalog_Searchable.jpg
Dennis Carpenter has the 8BA-10094 as a front bearing '40-'64, but their rear bearing is B6A-10095-B '56-'64. And, DC also has a generator rear bushing 78-10128 for '38-'55. That looks like the bushing in my starter.
Does anyone know if those bearings are what I need for a '51 6 cylinder stock 6 volt generator? I get SO confused...
I'd like to order the parts before I take the truck down again.
  #1330
Old 04-30-2014, 10:42 PM
old_dan's Avatar
You might try finding a generator/electric shop. There must be one in the Riverside area. It could be that the rear bearing is pretty generic bushing stock.
Dan
  #1331
Old 04-30-2014, 10:46 PM
bobbytnm's Avatar
Dan beat me to it.
I'd call around to the local shops, there's bound to be one that rebuilds starters, generators, etc. I'll bet you can find the parts locally.
Here in Albuquerque we have a great place that's been around forever. The guys seems to have parts for everything.
Bobby
  #1332
Old 04-30-2014, 10:53 PM
Just another Joe
Quote:
Dan
Quote:
Originally Posted by bobbytnm View Post
Dan beat me to it.
Bobby
My question is: does that generator have 2 bearings or a front bearing and a rear bushing? I want to get the parts before I take it apart.
  #1333
Old 04-30-2014, 11:41 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Joe, as I read my original Ford parts catalog, 6's and 8's used the same generator. There were two different ones available, one 35 and one 40 amp, but both show fitting 6 and V8.
  #1334
Old 05-01-2014, 12:06 AM
ALBUQ F-1's Avatar
postin' fool
Quote:
AFAIK all internals are the same and both are bearing front/bushing rear.
  #1335
Old 05-01-2014, 12:21 AM
52 Merc's Avatar
Except for the endplates; the 6's gen endplates had ears for mounting. AFAIK all internals are the same and both are bearing front/bushing rear.
The catalog makes no references to mounting ears. This is for the "Generator Assy, Less pulley, bracket and bolt." (10002) Perhaps this is one of those things that's different between production supplied parts and service parts, which oftentimes are more generic for multiple applications.
1952 Ford F-8 pilot31 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 08-04-2016 09:41 PM
Daytona 2012 firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-28-2012 10:27 AM
Help with possible engine/tranny choices HkyswiM 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 04-10-2012 02:27 PM
1995 F350 7.5L - Can Anyone Identify This Part? cougarman001 1987 - 1996 F150 & Larger F-Series Trucks 5 01-22-2012 08:01 AM
What Turbo is this? Rubidon 1999 - 2003 7.3L Power Stroke Diesel 10 06-28-2010 09:45 PM
Tags
1951, 51, f4, ford, horn, motor, nyc, parts, signals, towing, truck, trucks, turn, wheels, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
