'51 F4 project - Page 88 - Ford Truck Enthusiasts Forums
'51 F4 project
  #1306
Old 04-25-2014, 01:23 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Originally Posted by ALBUQ F-1 View Post
NO!
The drag link goes back to the steering box, is that what's stuck? Or is it the connecting rod between tie rod ends?
I'm trying to remove the spindle arm from the drag link.
I have the nut loose, but the arm won't move down off the drag link.
What's holding it? Oh, and I'm just resting it on the axle for the pic. I know that much...
  #1307
Old 04-25-2014, 01:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Take out the cotter pin and the plug in the end of the drag link. Take the drag link off the ball, leave the ball in the arm.
  #1308
Old 04-25-2014, 01:42 PM
Just another Joe
I can see from the parts catalog drawing that this is a tapered fit on the ball. But I can't understand why it won't release when I smack it with a hammer.
Pages from Illustrations Catalog_Searchable.pdf
  #1309
Old 04-25-2014, 01:52 PM
Just another Joe
Thanks for the phone call and all your help Ross. I got your PM as well.
Back to work...
  #1310
Old 04-25-2014, 02:02 PM
arctic y block's Avatar
arctic y block arctic y block is online now
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
I would say ya need a pickle fork Bud
Two hammers work as well or better as it don't tear
anything up like a fork can.
  #1311
Old 04-25-2014, 02:46 PM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
drag link
If it is a tapered connection like a tie-rod end, whack the steering arm on the outer end 90 degrees from the threads.
This will distort the hose a little and it should pop out.
Tractormanbill
  #1312
Old 04-25-2014, 03:04 PM
Just another Joe
So, after getting more info about what I'm trying to do from Ross, I now have the spindles removed along with the drag link. The old king pins will basically fall through the old bushings, so they were definitely worn.
I checked the components of the drag link and there is no noticeable wear to the ***** on the steering arm or the spindle arm stud. But the whole drag link does need a good cleaning, just like Ross told me it would.
I think when I lubed the truck I must have missed some of the grease zerks in the steering components, as the grease is all old and I don't see any of my new grease in any part of it.
And now, after seeing the drag link disassembled, I think it may not have been adjusted properly, since the rear plug was not flush with the end as was the front plug. Maybe there was slop in there as a result. I'll definitely check the adjustment when I put it back together.
One last pic of all the dirty stuff before it's off to the machine shop.
  #1313
Old 04-25-2014, 03:19 PM
ALBUQ F-1's Avatar
postin' fool
Having clean, fresh-painted steering parts is worth 5 mph, too.
  #1314
Old 04-25-2014, 05:59 PM
Just another Joe
Well, I'll see about that extra mph. Maybe all the way up to 47?
Dropped off the spindles, pins and bushings at the machine shop. He said they'd be done this afternoon or Monday.
I have a little time now to clean up all the other parts and prepare for assembly.
Thanks everyone for your suggestions. A special thanks to Ross.
  #1315
Old 04-28-2014, 11:32 PM
Just another Joe
I got my spindles back from the machine shop today. I was looking at the drag link, which I took apart to clean out all the old grease and check for wear.
So, I'm now thinking about putting it back together, and I looked in the Shop Manual for a pic. This is what's shown. My question is this:
Is this the correct order for the ball seats and springs for both ends of the drag link? They're in the same order left to right except for the plugs, instead of opposite each other as I thought...
Just checking so I don't screw it up...
  #1316
Old 04-28-2014, 11:57 PM
ALBUQ F-1's Avatar
postin' fool
Yes, the diagram is correct! When I took mine apart, they were opposite-hand (mirror images), and my pitman arm ball was worn to an oval.
Make sure all the grease passages in the drag link are open.
  #1317
Old 04-29-2014, 12:33 AM
Just another Joe
Thanks Ross.
I'll reassemble it correctly and make sure the grease gets where it should.
  #1318
Old 04-29-2014, 03:29 PM
Just another Joe
Just a before and after pic of the spindles, and drag link. But I also wanted to mention the shop that pressed and reamed my bushings. They did a great job:
Karl's Auto Machine Shop in Corona, CA. Karl also told me he works on flatheads, so I'll definitely take mine there if it ever needs work.
Karl
Before. That pin on the right is the one I had such a hard time getting out. Notice the black scoring...
After
And, it's obvious the two ends of the drag link are different. But I didn't notice the difference until after I started cleaning it.
  #1319
Old 04-29-2014, 06:35 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Dang you work fast!
That would have taken me weeks to get done.
Looking good
Bobby
  #1320
Old 04-29-2014, 07:55 PM
Just another Joe
Quote:
Originally Posted by bobbytnm View Post
Dang you work fast!
Looking good
Bobby
Thanks Bobby. I'm on vacation so it's pretty easy to get stuff done on the truck. The shop took the spindles in Friday afternoon, and I picked them up yesterday afternoon. As I said, they did a really nice job.
Started working on it at 7:30 this morning and just got the shop cleaned up a few minutes ago. Besides cleaning all the parts to paint, I had some small ridges to take out of the axle holes so the new pins would fit, but now Betsy's back together. I'm anxious to see if the steering wander is gone. Besides the new king pins, I adjusted the drag link according to the Shop Manual, and it's tighter than the PO had it. There's no wear in it's parts or to the ***** on the spindle arm or steering arm. I greased everything up good, repacked the wheel bearings (which I just did a few weeks ago).
I'm gonna shower and take her out to dinner, so to speak.
1960 f350 express bed (9ft) 57to60fords 1957 - 1960 F100 & Larger F-Series Trucks 5 12-21-2012 11:01 AM
test pic scmbmw User Gallery & Picture Display 1 09-29-2012 02:32 PM
Hot August Nights pics hotfalcoon 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 08-20-2011 07:54 PM
nose dive 503racing Offroad & 4x4 30 03-11-2011 04:42 PM
Carburetor questions rodeojunky 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-08-2010 06:54 PM
Tags
1951, 51, f4, ford, horn, motor, nyc, parts, signals, towing, truck, trucks, turn, wheels, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
