'51 F4 project - Page 85 - Ford Truck Enthusiasts Forums
'51 F4 project
  #1261
Old 04-04-2014, 09:02 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Originally Posted by ALBUQ F-1 View Post
If you had the reamer, you could do it yourself!
Anyone have a picture of what this reamer looks like?
Or where to get one?
  #1262
Old 04-04-2014, 09:32 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I have a few piloted reamers.....do you know the king pin diameter?
  #1263
Old 04-04-2014, 09:35 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
His is 1.12" (1-1/8"?)
This is what they look like in general
  #1264
Old 04-04-2014, 09:57 PM
tinman52's Avatar
Welder User
The type I have are adjustable......I have one 1 1/16-1 1/8.
  #1265
Old 04-05-2014, 08:36 AM
Marauder2004's Avatar
Marauder2004 Marauder2004 is offline
Marauder2004 has a good reputation on FTE.Marauder2004 has a good reputation on FTE.
Joe, for what it's worth, I did not find a local machine shop to ream mine either, but I did find an independent alignment shop that had the equipment and knew how to do it. I dropped off the spindles, new bushings, and pins and they were a perfect fit the next day!
  #1266
Old 04-05-2014, 09:02 AM
Just another Joe
Wow! Thanks for the replies fellas. I've never seen any of those types of reamers.
So the bushings are removed first, new bushings pressed in, and then both reamed in the same action to keep them lined up properly. Makes sense to me.
  #1267
Old 04-05-2014, 10:46 AM
tractormanbill's Avatar
tractormanbill tractormanbill is offline
tractorman
tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.tractormanbill has a great reputation on FTE.
Reamers
On the adjustable reamer the cone goes in the bottom to center the reamer, you set the adjustment to the correct size with the upper & lower nut and then feed the reamer down through the bushing.
Tractormanbill
  #1268
Old 04-05-2014, 09:30 PM
Just another Joe
Well, I've searched the web for a reamer in 1.129 size (the spec is 1.129 to 1.131). I mic'ed my new pins, and they're 1.129 just like Ross said. I haven't found a reamer that size, adjustable or otherwise.
On another note, we had the granddaughters over for a while this morning so I got them all in the cab with me. It's a tight fit, and the littlest wasn't happy after a short while (which I kinda expected).
So, when I was mounting the flag holders to the bed, I also secured two chairs back there. One is for my son and the other for a granddaughter to be named later. Probably the 3 year old. We can strap her car seat to the chair if needed.
Then, of course I had to test drive to check the security of said chairs. I continued the drive until I hit a milestone. No vehicles were damaged in the hitting of this milestone.
I tried to get a pic just as the odometer turned, but that's gotta be as unsafe as texting while driving. She had 25,720 on there when I got her in July, 2011. Of course the speedo cable was broken, so I have no idea what the true mileage is. Not exactly a daily driver, eh? Haven't quite caught up to Ross and his wild adventures to and from Truckstock.
  #1269
Old 04-05-2014, 09:48 PM
ALBUQ F-1's Avatar
postin' fool
To be honest Joe, I worry about the little ones in the cab or elsewhere -- be safe!!
  #1270
Old 04-05-2014, 09:53 PM
Just another Joe
They won't be in the truck without seat belts until the parade starts. And then, if I hit 5 mph it will be unlike last year. I want to have the 10 year old next to the door, and she has enough sense not to open the door!
If one is strapped into a chair on the bed, her daddy will be watching her. I think we're good, but I understand your concerns.
  #1271
Old 04-05-2014, 10:03 PM
tinman52's Avatar
Welder User
Joe, I'd be happy to loan you my reamer, but it's not quite big enough......only goes to 1.125".
Surely there is a shop in your area that can do the job?
  #1272
Old 04-05-2014, 10:11 PM
Just another Joe
My son knows a guy. He's going to check with him for me to see if he has one big enough.
  #1273
Old 04-06-2014, 11:43 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
Just a suggestion - you might try some local hotrod/custom places and/or people. They may be able to recommend a machine shop to do the work.
A local NAPA said they could do mine, but wanted 3 hours of shop time to do it. With the help of a mechanic friend, I found a local machine shop that was able to do it for $40.
  #1274
Old 04-06-2014, 11:59 PM
ALBUQ F-1's Avatar
postin' fool
Your bushings are on the small size for a shop that does semis, check with one of them.
  #1275
Old 04-07-2014, 12:01 AM
Just another Joe
All good ideas guys. Thanks. I'll be checking on this soon. Unfortunately, I have to go back to work tomorrow.
1952 Ford F-8 pilot31 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 08-04-2016 09:41 PM
Daytona 2012 firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-28-2012 10:27 AM
Help with possible engine/tranny choices HkyswiM 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 04-10-2012 02:27 PM
1995 F350 7.5L - Can Anyone Identify This Part? cougarman001 1987 - 1996 F150 & Larger F-Series Trucks 5 01-22-2012 08:01 AM
What Turbo is this? Rubidon 1999 - 2003 7.3L Power Stroke Diesel 10 06-28-2010 09:45 PM
Tags
1951, 51, f4, ford, horn, motor, nyc, parts, signals, towing, truck, trucks, turn, wheels, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
