'51 F4 project - Page 46 - Ford Truck Enthusiasts Forums
'51 F4 project
  #676
Old 01-18-2013, 09:09 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Original Battery and Starter Cable gauge for 6 volts
Quote:
Originally Posted by Jolly Roger Joe View Post
I was looking at the starter cable when I was replacing the battery cables. It does look thinner, but it is much thicker than the old battery cables, so I'm not sure what gauge it is. I think it's the original starter cable.
So this brings another question to mind. What was the actual gauge of the original cables in these 6 volt trucks? Was it 1/0 like my new cables? Or was it more like 4 gauge or 2 gauge? I know you can use 4 gauge in an 80 amp circuit and 2 gauge in a 100 amp circuit.
Somebody on here must know what was stock...
  #677
Old 01-18-2013, 09:37 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Joe,
Glad you were able to get the cables while I was gone. We were out hunting places to get a flu shot for the family and came up short. We came home about 10 minutes after you left. Let's do some better planning next time so I can give you a ride in the panel truck.
Let me know if you want the solenoid to starter cable done. I may have one already made in that length. If not, I can get one made.
BTW, the cables are 2/0. I found that 1/0 is too thick and 2/0 works just fine.
  #678
Old 01-18-2013, 09:45 PM
Just another Joe
Quote:
Originally Posted by 51PanelMan View Post
Joe,
Just goes to show you what I know... I thought 2/0 was thicker than 1/0.
Actually, I think it is, at least according to this chart...
Sorry I missed you. I actually stopped to eat dinner, since I didn't get breakfast or lunch. So that's why I got there after you left. Wish you could have found a place to get the shots. They're advertising availability at some food stores with pharmacies around here.
But I can't thank you enough for getting the cables made for me. They work really well. And if they are 2/0, maybe that's why my starter cable looks thinner?
  #679
Old 01-18-2013, 09:50 PM
51PanelMan's Avatar
You're right, Joe. It's been a busy week and the sizing slipped my mind.
What I should have said is that 1/0 is not thick enough, IMO, and minimum size should be 2/0.
  #680
Old 01-19-2013, 06:58 AM
Harrier's Avatar
Harrier Harrier is online now
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Well I learned something new on wire gauges.
I was wondering about the 1/0, 2/0 etc. I hadn't dealt in wire that thick before. So 1/0 if 0 and 2/0 is 00 etc. now it makes sense.
I love this site, where else can you say "Those are some sweet looking cables." without being looked at like a complete nut. I mean people already think I'm crazy....
  #681
Old 01-19-2013, 08:20 AM
Just another Joe
Quote:
Originally Posted by Harrier View Post
So 1/0 is 0 and 2/0 is 00 etc. now it makes sense.
Joe, that would be a correct comparison if we're talking about buckshot. Since "0" shot (.32" diameter) has 9 pellets per ounce and the slightly larger "00" shot (.33" diameter) has only 8 pellets per ounce.
  #682
Old 01-19-2013, 01:18 PM
South of BC's Avatar
South of BC South of BC is offline
South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.South of BC has a very good reputation on FTE.
...where else can you say "Those are some sweet looking cables." without being looked at like a complete nut.
San Francisco. But then you can just about say anything there without being looked at like a complete nut.
  #683
Old 01-21-2013, 12:03 AM
Just another Joe
Metal Bumping for a beginner
At the recommendation of AXracer, I got the 4th edition of the Key to Metal Bumping by Frank T Sargent for Christmas. It was a great stocking stuffer.
I read the book last week, and started to analyze the body damage on my truck using the methods described in the book. And while there's not a lot of body work to do on Betsy, I still am uncertain how to start. Here are some pics of what I want to bump. Hopefully, someone with experience will comment. I've never done any body work.
All of these shots are of the cab right side below the gas filler pipe.
  #684
Old 01-21-2013, 08:15 AM
51PanelMan's Avatar
Dolly on outside while hammering inside. Then alternate back and forth to get the high and low spots out until it's smooth enough for body filler.
  #685
Old 01-21-2013, 12:02 PM
Just another Joe
No video, but I drove Betsy to Costco this morning to fill the tank. It's the first time I've driven her that far. Only about an 8 mile drive, but lots of fun nonetheless.
Our California streets are not exactly in good repair, since we only give the state about $.25 a gallon to keep them repaired. So I bounced merrily along on surface streets. And I mean I thought I got airborne a couple of times.
My wife was following in the Ranger to fill it up as well. She checked my speed, and when I was showing 30 on my speedo, she said I was doing 45. That makes sense because it felt like a lot faster than 30. Guess the rear radials aren't tall enough. But it did capture the correct mileage... hmmm
I downloaded a GPS Speedo to my smart phone, but I couldn't get it to work...
Amazing how stiff this suspension is, as it has the 10,000 pound GVWR and NO weight on the back. If it was a Harley, I'd call it a hard tail.
  #686
Old 01-21-2013, 06:36 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
That is the joy of driving an old work truck. If you are running with no load you can set the air pressure in the duals a lot lower than the max rating. Doing that helps a little.
  #687
Old 01-21-2013, 09:43 PM
Just another Joe
Quote:
Thanks. I hadn't thought of lowering the tire pressure. How low do you think I can go? I think max pressure is 90 psi.
  #688
Old 01-21-2013, 10:20 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
You'll have to play with it a bit and see what works. I wouldn't be afraid to drop them down to at least 35 and see what happens. Remember, there's 4 of them back there and that's a lot of support for the little weight you've got.
  #689
Old 01-21-2013, 10:36 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
I run our F500 at 60 when unloaded. Using new bias ply 20" tires. If you don't go very fast, risk of overheating/blowout due to sidewall flex is not so bad. However, if dual tires touch, kerblewie!!
At 60, she's still stiff but not nearly as bad as at 80.
  #690
Just another Joe
Quote:
Thanks Wayne. I'll give that a try and see what happens.
New Motor Mount with "crack"? GaMachinist 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-09-2014 02:33 PM
1960 f350 express bed (9ft) 57to60fords 1957 - 1960 F100 & Larger F-Series Trucks 5 12-21-2012 10:01 AM
Hot August Nights pics hotfalcoon 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 08-20-2011 06:54 PM
1951 Ford F4 - Picking it up today. speedyweasel 1948 - 1956 F1, F100 & Larger F-Series Trucks 52 08-13-2011 06:20 PM
Carburetor questions rodeojunky 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 09-08-2010 05:54 PM
Tags
1951, 51, f4, ford, horn, motor, nyc, parts, signals, towing, truck, trucks, turn, wheels, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
