Panel Truck move and met a Ford trucks member - Page 2 - Ford Truck Enthusiasts Forums
Old 08-15-2011, 09:33 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
I just think they made better plywood back then. I know I found pieces of plywood in old houses and used in garages I know have been there for years and other than ragged edges it's all there. Leave a piece of plywood sit in your garage a few days and it'll bow so bad you could use it for a skate board ramp. I know, I have a new piece of 1/2" piece of plywood in my shed that I'll never be able to use for anything. If I were to replace the wood in my panel I'd sure strongly think about using marine grade.
Old 08-16-2011, 07:08 AM
52 panel's Avatar
52 panel 52 panel is offline
52 panel is starting off with a positive reputation.
Plywood in mine, too. The back corners had began to rot, other than that, it was in decent shape. Mine was painted black, both sides which was probably the original color. I'm told (can't confirm) the truck was a police paddy wagon in Canada when new which might explain the black. I bought a piece of 3/4 inch cabinet grade oak plywood. I painted the underside with marine polyurethane (6 coats) same color as the truck. Inside I used a sealer/stain then 7 coats of floor polyurethane, like you would use on oak floors in your home. I have a piece of carpet that matches my interior that I put over the floor if hauling things that might scratch.
Old 08-16-2011, 08:31 AM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
I think Ford had their own lumber operation - They cut lumber in Northern areas of Mich and hauled it to one of their plants in Detroit where it was used for various body parts, packing crates and what ever else they needed wood for.
If I remember correctly they used their own thickness standards
Of course the above could be imagination.
Tags
met
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
