anyone know how to check a tfi module?
I am looking for info on chking my TFI module off my 88 F150 with 5.0 AOD. I know I can take it in to be tested at AZ or Advance, but I do not always trust what I find at those places, as I know alot of times, they receive NO training on it. I am doing a custom installation of the 5.0 EFI & AOD trans into my 67 Fairlane. I have no spark currently at the plugs, coil chks ok, tach lead is pulsing, so I am guessing stator is ok....
Anyone... Bueller? Bueller? Bueller?
This is a transplant job. The car has not run yet. This is why I am chasing the no spark problem. I installed the engine & trans from a 88 F150, into my 67 Fairlane. I have swapped a 91 Mustang top end onto the motor in place of the truck intake (makes air inlet lined up better on pass side). I have also installed a COMPLETE 91 Mustang harness into the car. I have used only must have Fairlane switches, otherwise, original Mustang items have been used. But injectors & distributor are stock truck items. I have found they are compatible with the A9 Mustang computer I am using. A/T Mustang stuff with A/T truck stuff. Sounds like a headache, but it is coming along nicely. Got some pics if you are interested. RSO
I have a Jeff Probst book. To be honest.. I had not thought of checking it that way. As I have not started it yet, it did not occur to me to check that option. An easy starting point, if I get nothing from it, I have lost nothing. Thanx Franklin2!
Still happliy taking anyones input on this though. RSO
show voltage on both sides with key on. I took franklin2's advice and ran KOEO last night. Got code 67 (neutral saftey switch related) & 85 (canister purge solenoid). 85 is dead on (not hooked up at this time. Going to persue 67 this weekend in between downpours (did I mention I have no garage & a gravel driveway...?) Anyways, thanx for the advice, keep it coming, I will update if/when it changes. Always open to more info though~! RSO
THE BLUE HEAP
06-06-2016 05:25 PM
Pickupmanx2
03-03-2015 11:04 PM
