Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-13-2011, 09:45 AM
litefootin litefootin is offline
Garage is empty, add now
litefootin is starting off with a positive reputation.
OK #'s Dummy , can u help me ???
I saw that your name is Bill , good morning , I'm Don Decker , Nevada , I have a p/u & a donnor van these r there #'s
E10 SH 121 316 Model E100
E10 SH 153 679 " E104
also , about the weight above the gas tank , how important is it ???
and where is the best place to try to get replacement parts , nice meeting u , and Thanks in advance ...dd...
  #2 (permalink)
Old 08-18-2011, 05:26 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by litefootin View Post
I saw that your name is Bill , good morning , I'm Don Decker , Nevada , I have a p/u & a donor van these r there #'s
E10SH121316 / Model E100
E10SH153679 / Model E104
also , about the weight above the gas tank , how important is it ??? and where is the best place to try to get replacement parts?
Welcome to FTE
E10 = Econoline Pickup.
S = 144 1V I-6.
H = Lorain OH Assembly Plant.
121316 = 1961, assembled December 1960.
E100 = Econoline Pickup, 3,600 lbs, Gross Vehicle Weight Rating.
S = 144 1V I-6.
153679 = 1961, assembled March 1961.
E104 = Econoline Pickup, 4,350 lbs. Gross Vehicle Weight Rating.
Where is the VIN, Model code for the donor van? Look on the registration, see if the VIN you posted matches the donor van.
Peeps replaced damaged left doors with used doors. 99% of the time, they didn't install the original Warranty Plate on the replaced door.
inre to the weight above the gas tank, all I can tell you is the rear axle capacity is 2,300 lbs.
You'll have to ask this question to someone that owns one.
Many powertrain parts can be bought in autoparts stores, body parts may be difficult to find.
Anything specific you want?
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 08-27-2011, 09:31 AM
Thanks 4 the info , but , the second # I gave u is from the van , the plate is on the drivers door frame , and its original , the entire van is org.
looking 4 the battery box lid , steering wheel , custom dash panel ?? those r some of the things that come 2 mind..........Thanks ...dd...
  #4 (permalink)
Old 09-01-2011, 12:30 AM
Ford Parts Guru
2013 Ford Escape
Thanks 4 the info , but , the second # I gave u is from the van, the plate is on the drivers door frame , and its original , the entire van is org.
The VIN of the second number has a series code of E10 = E100 pickup.
The Model Code is E104 = E100 Pickup.
Since these codes are pickup only, the Warranty Plate cannot be original for a van.
__________________
  #5 (permalink)
Old 09-01-2011, 07:36 PM
Bill Well , the Van above the plate has in ink pen the #'s F 747 and above it the same #'s are stamped into the door post , it didn't come with a title , so who knows , the van is red , the color on the plate is J , on the pickup its S , it will all end up on the pickup , and it has a title , so Thank You for your help , ...dd...
  #6 (permalink)
Old 09-10-2011, 08:54 AM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
Look at the cross braces on the back tailights. That is the easiest location to find the serial number stamped into the sheetmetal of these econolines. The 2nd location for sheetmetal stamped serial number is on the lip of the engine compartment on the right side. Here you have to remove the right panel and clean off the goop they use to seal the panel to the lip. There again is the serial number of the vehicle. You may find these will not match the tag on the door meaning the door has been switched.
I would post a pic of a brace with number here to help as a reference. But I'm unable to insert the pics here.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
Tags
1961, battery, box, econoline, located, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
