Please advise on 1994 F-150 351W upgrades.
hey guys. just joined here. i have no idea what to do and where to start.
let me begin by saying that i bought the truck from a guy down in phoenix, and he had already fitted 2.5in magnaflow true dual exhaust and the truck also does not have a catalytic converter. up here in flagstaff, they dont require emissions so its OK.
other than that, the truck is bone stock. the 351W in it has 111,000 original miles.
i dont know what is a waste of time and money and what is not. so some advice would be greatly appreciated! my goal is just to get more meat out of it. HP and TQ wise. would prefer not to spend a lot of cash, but all suggestions are welcome.
thanks
update: i got a professionally done fuel system clean at sears (i work there as a college job) and its defiently improved the throttle response, but not enough
so this is my next step..how's everything look? right parts and such? im new to this world.
MSD Ignition 8482 - MSD Distributor Cap and Rotor Kits - Overview - SummitRacing.com
Summit Racing SUM-853011 - Summit Racing® High Output Ignition Coils - Overview - SummitRacing.com (MSD one is out of stock)
Taylor Cable 74258 - Taylor Spiro-Pro Spark Plug Wire Sets - Overview - SummitRacing.com
http://www.summitracing.com/parts/HED-89420/
thanks
I've always found that a fast and cheap way to get more HP and Torque out of a used vehicle, is to run Fuel System Cleaner through it once, usually brings it back to life a little bit, then invest in a K&N Cold Air intake, usually a little over 100 bucks for the kit. With a 351 you should get 2 mpg better, a little more torque, and faster throttle response. Cheap and easy.
oh im happy, i just want more power. but driving a good condition stock 351W is great. they really scoot.
on
Skip the CAI and simply substitute an intake snorkle from an I6 truck and an aftermarket drop-in filter, then you'll have a true "cold air" intake. Add 1.7 rockers and longtubes or even shorties if you don't want to hack up the rest of the exhaust and you'll see noticable gains. Also do what is called a 6 liter tuneup(why is it calld that anyway?) which includes a high output coil, wires, plugs gapped a little wider, and a timing advance, this is also good for a noticable boost under the right foot.
It's called the sixlitre tuneup because it makes your truck feel like it has .2 more liters! J/K it's called that because a member on FSB forums with the screen name Sixlitre came up with it. It's basically just a good tuneup. Replace the stock ignition parts (coil, cap and rotor, and wires) with good high quality aftermarket stuff. Here's a couple of good links to threads on the 351 for mpg upgrades:
ignition upgrade and timing bump (no 56K) - FSB Forums
The ULTIMATE better MPG thread! - FSB Forums
i am going to do the timing advance for sure.
headers are definitely worth it. but a cam is a little extensive to just get some snort out of it. a bigger cam wouldnt be worth it unless you wanna start a rebuild on the whole motor. a lot of times, if you put a bigger cam in a motor with over 100,000 miles, it wont take it very long and youll start breaking internal parts. Thats whats always happened with my motors anyway. A performance tuner would be a good substitute for a cam though if you can find one for cheap.
The few tuners that are available are really not worth the cost. Do the sixlitre tune up and headers. If you still want more pep then look at swapping gears in the diffs. Anything more then that and you'll have to start rebuilding.
