Dont laugh too hard at my first ever patch welds!!
Old 08-12-2011, 07:30 PM
canadian_diesel1964's Avatar
canadian_diesel1964
canadian_diesel1964 is offline
Well here we are...never even fathomed this a few months ago...the cowls came with the truck so I saved as much of the original as I could and cut the patches to fit...dont laugh too hard...I am good at grinding!! the whole side was flappin in the wind so I have to say I am damn happy!!
Old 08-12-2011, 08:15 PM
reed1951's Avatar
reed1951
reed1951 is offline
Hey man, that looks good to me
Old 08-12-2011, 08:20 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Consider using a flanging tool next time as it is way stronger than butt welding panels. It also saves a ton of work.
Old 08-12-2011, 09:07 PM
rhopper's Avatar
rhopper
rhopper is offline
Nothing wrong with that. Beads could be smaller, but you can grind it down. Just don't overheat the metal by grinding too long.
Old 08-12-2011, 09:28 PM
canadian_diesel1964
thanx guys...i love this place....I am sure I can slow down the wire speed a bit on the next one...by the time this ones done I should be pretty good at it...I will sure be buying a flange tool too!!
Old 08-13-2011, 12:57 AM
POS-F500's Avatar
POS-F500
POS-F500 is offline
Looks good! I'd rather grind down boogers than burn through metal any day!
Old 08-13-2011, 01:12 AM
mOROTBREATH's Avatar
mOROTBREATH
mOROTBREATH is offline
Doing your own work and pushing yourself to learn how to help yourself something to laugh at?
Nonsense. Congrats man, farther in the body world than I've made it.
Old 08-13-2011, 04:50 AM
spurredon's Avatar
spurredon
spurredon is offline
Looks like you got good penetration. That the main thing, you don't want you patches popping back off after you get them all pretty looking!
Old 08-13-2011, 08:44 AM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
I wish I had a welder. Looks good to me.
Old 08-13-2011, 09:06 AM
canadian_diesel1964
Man u guys are awesome....there is a great feeling of accomplishment for sure...I will keep posting the progress...
Old 08-13-2011, 09:49 AM
53OlderThanMe's Avatar
53OlderThanMe
53OlderThanMe is offline
Looks good to me. I always say I am an OK welder but an excellent grinder. Go look at some of my welds on my build site if you wanna feel good about your welding skills
Old 08-13-2011, 09:54 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
Its always cool to see an improvement like that, knowing you did it yourself. BYE BYE rust!
Old 08-13-2011, 12:11 PM
ZOOT's Avatar
ZOOT
ZOOT is offline
First time weld
Congrats on pushing yourself to learn. The welds look good to me. What kind of a welder are you using? MIG ? Maybe just a little too much filler. Don't take it wrong, just trying to help. I assume these were all spot welds. You probably know to weld one spot then another somewhere not close to the last one to avoid heat build up. Use a wire brush on each spot to keep the metal clean for the next one. You could probably spot weld in between some of your existing ones to avoid gaps after you grind. I learned a trick about grinding down spot welds. Use a cut off wheel and carefully scuff off the dome of the spots with the edge of the cut off wheel. Saves alot of grinding and heat build up. Go gently or you'll cut into the panel. By the way did you ever get the pics of the hood nose ornament I sent you?
Old 08-13-2011, 12:15 PM
ZOOT's Avatar
ZOOT
ZOOT is offline
And after grinding.....
Old 08-13-2011, 01:32 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
REALLY NICE JOB!!
I hope I can do as good!
What kind of welder did you use?
Quick Reply: Dont laugh too hard at my first ever patch welds!!
