clutch problems!!
clutch problems!!
today i was driving my 1993 ford f150 xl 4.9l home and i started to smell something burning, when i got home the truck was smoking and the clutch pedal was sticking when i realeased it, it would stay at about half. i opened the hood and crawled under the truck and the transmission was smoking! can anyone help? i rely on this truck for everything, and need help fast
The pedal not fully releasing could be resulting in your clutch slipping 100% of the time, resulting in excess heat & smoke from the clutch area.
I'm assuming it was an asbestos-like smell (comes from clutch & brakes) as opposed to oil or electrical?
In any event, I'd spend tonight removing the transmission and opening up the clutch to investigate, replacing it will be the weekend's task.
A clutch kit - includes throwout bearing, pilot bearing, alignment tool, pressure plate & clutch disc - can be had for less than $100 on sale. Look on Rock Auto's site to see what some of your options.
RockAuto Auto Parts
Remember, though, nobody here has SEEN your truck, and diagnosis over the Internet is a best-effort affair.
IOW there could be more involved than perhaps even you are aware of; for example, an engine or transmission that, for whatever reason, is dumping fluid into the clutch assembly....
RockAuto Auto Parts
AKHunter93
20
02-15-2016 12:06 PM
CaptainFacePunch
22
03-22-2015 10:21 PM
putzhall3
06-08-2005 02:08 PM
KSever
02-24-2005 03:02 PM
