Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 08-12-2011, 07:02 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
Ozzie battery options
Anyone got any recommendations for F250 batteries?
Went to start my truck today and the batteries gave up. Checked electrolyte level, and charged for an hour, only got to 11v then dropped to 9v after an attempted start. I'd guess they've both gone south so I'm off in the missus car to buy two tomorrow. She wasn't too happy about me using her car, but she's got no choice cause I'm on horse float pulling duty on Sunday
From a search around the net it looks like I'm going to be up for $250 a pop for something decent.
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #2 (permalink)
Old 08-12-2011, 11:41 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
Garage is empty, add now
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
I got a pair of Super Charge MF65's 800CCA $195 each
__________________
Brian
03 F250 XLT LB . Full Engine build with all the goodies. Tuned by Matt
- cant wait until my motor blows so I can blame someone else -
join the Australian Chapter here-Join Chapter
  #3 (permalink)
Old 08-13-2011, 07:46 AM
2005 Ford F-250
Couldn't find those. Ended up with a pair of Besco-Century batteries - they reckoned they were the best, cost me $248 each, perfect fit. The hint from 'The Battery Factory' was to have the batteries on a smart trickle charge system if not using the vehicle daily - which I don't. I think the -8 temps down here really finished off the old batteries.
I'll rig up a trickle feed and have my own plug-in F250 here in Oz.
__________________
  #4 (permalink)
Old 08-13-2011, 10:40 AM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
I mounted a forklift style plug out the bottom of the front grill which goes to battery #1 for when the truck is sitting:
Click the image to open in full size.
That way if I am an idiot and forget to unplug it, it will just snap free and no damage done.
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #5 (permalink)
Old 08-14-2011, 07:46 AM
2005 Ford F-250
They're called Anderson Plugs over here. I've got one under the rear bumper, but the dual battery system - added by the PO - isolates the plug when the main batteries go below 12v. I've now rigged up a Ctek charger into the 12v dash outlet and run the lead into the garage.
Those batteries I picked up are rated at 750 CCAs each.
All the funny gremlins - like false alarms from the burglar alarm, slow window and roller winding, and long starts - were all cast off with the old batteries
__________________
  #6 (permalink)
Old 09-21-2011, 01:38 PM
FJB_6989 FJB_6989 is offline
FJB_6989 is starting off with a positive reputation.
As for batteries, my truck has two Caterpillar ones rated at 1000 CCAs each. Caterpillar are open 24/7 for parts and they were less than $200.00 each. The beauty is you get a 5 (FIVE) year warranty in a 4x4 and six years in a 2wd. No other battery comes close.
  #7 (permalink)
Old 09-22-2011, 01:17 AM
Quote:
thats a good price for 5yr warranty. I will look at Cat next time.
__________________
Brian
  #8 (permalink)
Old 09-22-2011, 05:13 AM
2005 Ford F-250
Really good tip there! Cat batteries ! Wish I'd known that at the time!
__________________
  #9 (permalink)
Old 09-22-2011, 03:09 PM
xran's Avatar
xran xran is offline
2007 Ford Falcon
xran is starting off with a positive reputation.
Chinstrike
the Cat batts on the boat are 1200cca and have the same warranty out here. Only problem is we're on our 3rd complete set (2 banks of 24V for radios, 24V emerg, 24V starters for 3x C18's and 24V each for 3516's) in 2yrs. That has to be getting expensive for Cat!!
__________________
THE YARD - 1994 turbo'd Fairmont 280rwhp @ 6psi, 1994 Ute w/351C SKID PIG, 2007 XR6turbo 433rwhp 11.8 @ 120mph shopping trolley, 1974 F-100 trayback 302C, C4, 9"
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
