2008 brake job - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2008 brake job
Old 08-12-2011, 04:56 AM
chromyelow1 chromyelow1 is offline
chromyelow1 is starting off with a positive reputation.
2008 brake job
its been a while since i did a brake job and they were mostly to older vehicles but now the oldest one i have is an 01, but my question is simple...my wife has an 08 expedition eddie bauer, do i need to open the brake fluid resevouir or do i leave it closed while i change out the pads and compress the brake pistons? thank you in advance
Old 08-12-2011, 10:44 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I always pop the cap and compress slowly. Have someone check to make sure it doesn't overflow.
Old 08-12-2011, 03:53 PM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
Quote:
Thats what I do. Walmart sells a syringe it the automotive section that you can draw some fluid out it needed.
Old 08-13-2011, 05:33 PM
Boomer1956 Boomer1956 is offline
Boomer1956 is starting off with a positive reputation.
1. remove cap and do not let any fluid drip.
2. use an old syringe to remove about 90% of the fluid, its trash.
3. compress piston very slowly. critical w/anti-lock systems
4. remove more fluid not letting it get so low as to let air in to the bottom of the master
5 refill with brand new fluid so when you bleed you can see the fresh fluid at each caliper,
6 Bleed,,RR, THEN LR, THEN RF, THEN LF
Front brake job Mcroz 1999 - 2003 7.3L Power Stroke Diesel 20 09-17-2013 02:57 PM
Parking brake cable. BigBlue92 1987 - 1996 F150 & Larger F-Series Trucks 5 03-30-2012 04:39 PM
Right Front Brake Sticking After Brake Job 2003Navi 1997-2006 Expedition & Navigator 7 11-13-2011 10:37 PM
'99 F350 Dually rear brake hoses Supercab 1999 - 2003 7.3L Power Stroke Diesel 8 07-22-2011 07:33 AM
Brake problem mike0179 Ranger & B-Series 3 12-11-2006 04:29 PM
Tags
08, 150, 2007, 2008, 64, brake, break, expedition, f150, f250, ford, jo, job, navigator, rake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
