P1151 OBD Trouble Code - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-12-2011, 02:14 AM
99v10sd 99v10sd is offline
99v10sd is starting off with a positive reputation.
I'm driving a 1999 F25o V10 Superduty, it has a manual transmission with 4WD.
Around town it behaves wonderfully. Although the mpg tends to bounce between 10 and 13. When I take a road trip, get it out on the highway and set the cruise... bam, about 200 miles out I start losing power like I'm out of fuel or something. Kick it down a gear and rap it and grab 5th gear again and it straitens out for a bit , then does the same thing again then trips the p1151 code. get back in town, no codes, no problems till the next trip to college. Usually I'm pulling grade or a trailer when this happens. lack of HO2S-21 Switch, sensor indicates lean. Can't things just break and stay that way till you can fix 'em???
Old 08-12-2011, 07:15 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Might be something as simple as a restricted fuel filter.
Old 08-12-2011, 10:48 AM
I should have mentioned that i replaced the fuel filter and fuel pump last year hoping to cure my problem. I should say I fixed another intermittent problem and i was hoping the 2 problems were somehow connected. Never know until you hit the road. Been running "sea foam" the last 2 tanks hoping to clean injectors. I can't hear any vacuum leaks, connections all look good. was thinking egr valve or o2 sensor. I was hoping to avoid playing "replacement technician".Limited resources,{did I mention the kid in college}350 miles from home [
Old 08-14-2011, 10:03 PM
round trip to college
Made the trip down, loaded with stuff. Pulled a 12' U-haul trailer. Left the truck in 4th gear 2500 rpm 60+ mph going south. The 1151 code tripped again about half way down(150mi.) but the truck ran great. On the way home empty, with the trailer still in tow, I tried 5th gear at 2250 rpm. Ran o.k. for a bit then started to bog down. Had to gear down to forth and mash the gas just to maintain 55mph. Woulda thought I was running out of gas. Stopped and filled the tank, gave it a minutes rest and hit the highway again in 4th @2500rpm 60+. Again, no loss of power the rest of the way. But the mileage was down to single digits, OUCH.
1999 V10 running rough p1131 p1151 oachs83 1999 to 2016 Super Duty 1 10-13-2016 06:21 PM
Help! Codes P0136, P1131 and P1151 Denver Davis Electrical Systems/Wiring 7 02-13-2016 08:37 PM
Re: P1151 charlie268 Ranger & B-Series 2 07-25-2010 12:59 PM
Codes: P0401, P1151, P1131 Help! Wolf1200 1997 - 2003 F150 3 05-06-2009 02:28 AM
97 P1151 code pete315 Explorer, Sport Trac, Mountaineer & Aviator 2 06-22-2008 06:16 PM
Tags
1151, 1999, cf250, code, codes, engine, ford, obd, odb, odb2, otc, p1151, trouble, v10, wwwp1151com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
