hesitation/cutting out under acceleration?? - Ford Truck Enthusiasts Forums
Old 08-11-2011, 11:25 PM
ravens fan's Avatar
ravens fan ravens fan is offline
ravens fan is starting off with a positive reputation.
Hey guys..I have a 91 f150 300 6....truck has been hesitating and cutting and almost shutting off out when taking off from a stop and then will take off and will run fine the rest of the time... its getting pretty bad as its doiing it everytime i go from a stop?
would a bad fuel pump do this?
or is it something else?
thanks
Old 08-12-2011, 02:45 AM
Alec94F150XL's Avatar
Alec94F150XL Alec94F150XL is offline
Alec94F150XL is starting off with a positive reputation.
Mmm, TPS most likely, my trucks bucks up a storm from a stop all the way to a little past 2000 rpms. I hate it, everyone on the site has told me it's the TPS, I just haven't got the time or money right now to fix.
Good luck, and hope you get your answer.
Old 08-12-2011, 02:46 PM
ravens fan's Avatar
thanks for the reply! what exactly is the tps? and how do i fix it?
Old 08-12-2011, 02:53 PM
It's the Throttle Position Sensor, it tells your computer how much gas the truck needs based on how much throttle you give.
Also I'm guessing it's an EFI F150 right? Or is it carbed?
If it's carbed, then it could mean the carb needs to be rebuilt, or a faulty fuel pump.
There is a slight chance it could be because you have low fuel pressure, so I would check that before looking into the TPS.
Umm, as far as fixing it, I don't think you can, you just have to replace it.
Check out this link, it's about the symptoms we have, it's from FTE members.
http://www.ford-trucks.com/forums/14...-cruising.html
Old 08-12-2011, 02:56 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
The throttle position sensor is actually what keeps a vehicle from stalling out when coming from a stop by injecting a little bit more fuel. You can pick a new one up for about 40 bucks. It doesn't take very long to replace.
Old 08-12-2011, 03:00 PM
Yes, GNR22 said something I forgot. Great job, hopefully he can fix/pinpoint his problem now.
I know it's my TPS, just don't have time. Also whenever I do access the throttle body to get to the TPS, I'm going to try to clean everything.
Well Ravens Fan, hope we helped. Good luck.
Old 08-12-2011, 11:37 PM
ravens fan's Avatar
thanks guys that did help i will try to do a fuel pressure test but im having a feeling it is the tps and yes it is efi
Old 08-14-2011, 04:09 PM
UncleCracker302's Avatar
UncleCracker302 UncleCracker302 is offline
UncleCracker302 is starting off with a positive reputation.
i'd agree and assume it's the TPS. i just had the same problem that flared up a few weeks back and got worse until unbearable. at first it was my temp coolant sensor causing the engine to think it was running hot, but it wasn't. after doing that 5 min fix, the CEL was still on and the problem persisted. long story short, my buddy came by and read the computer, went and got the TPS, and replaced it. since then, i haven't felt the bog down that was there before. when you do replace it, take your time and remove the throttle body (and replace its gasket while you're at it) to make the install easier.
hesitation/fuel pedal issue? 20powerstroke02 1999 - 2003 7.3L Power Stroke Diesel 5 07-25-2016 07:23 PM
Hesitation at take off. prkranger 6.0L Power Stroke Diesel 13 04-11-2016 09:12 PM
Hesitation / miss off idle, all else fine. lanier1974 Ford Inline Six, 200, 250, 4.9L / 300 2 04-07-2016 03:14 PM
Hesitation on accerating Jammin1 6.7L Power Stroke Diesel 8 04-05-2012 08:59 AM
2005 6.0 turbo diesel E350 hesitates taking off at full operating temp mrjenkins79 6.0L Power Stroke Diesel 9 09-25-2011 11:23 PM
Tags
2005, 300, 460, acceleration, cherokee, cuts, cutting, f150, f250, ford, heavy, hesitates, hesitation, load, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
