Steering Wheel Change - Is it possible?
thx for the offer Chris, but I've got them already. I went overboard and bought the Ford Repair DVD's that all the Dealerships use.
Currently I have a 2005/2006, 2006/2007, 2008/2009, 2009/2010 (so 4 total). Back when they were available online (around 2006/2007) I didn't see the need, but now that Ford/Alldata are being info misers, I just figured it wouldn't hurt to just buy them
I will say though, that those Ford DVD's and even the Alldata Paid subscription aren't correct in the wiring areas. I found errors with both in my 06 F-150, my 08 Expy, my 09 Mustang...and last weekend with the 06 F-250. They diagrams are close, but for some reason Ford keeps changing colors and that info isn't getting updated
Got the wheel today actually. But my Expy is at the Dealership getting warranty work done, so I'm not pulling the airbag until I can afford downtime with the truck
also need to get the correct wheel puller.
It looks correct so far from the pictures I've seen on the internet. The fit test will be the final determination of course. Keep your fingers crossed. I'll let everyone know ASAP on the results
Just came across this thread. I swapped a Navigator wheel into my '02 Excursion (that didn't have all the buttons) and then did a direct simple swap of a Lincoln Blackwood steering wheel into the '05. The '02 was a lot of work- had to change clocksprings and do some wiring to figure out what was what. The '05 was a simple swap- 10 mins at most, as the buttons on both wheels were identical as were the plugs and steering column shafts.
However, I've been on the lookout to add a wood wheel to my dad's F-450. I think the newer Navigator wheel is a different style and I didn't think a wood wheel existed, but I see your Expedition does have wood and has the same controls! What I thought was previously impossible now looks very possible!
BTW, your stock F-250 wheel looks in OUTSTANDING shape! My '05 Excursion has an identical wheel, and at 57k, it is starting to get shiny and lose the texture to it.
Subscribed....I would like to update my 02 F350
How was the wiring for the door panels? Did you do all the power doors locks, power windows, and mirrors? I ask because I just ordered 2008 power fold/telescoping towing mirrors and I was considering doing the 2008 door panels (mainly to avoid cutting in new switches for the mirrors and staying oem).
I hadn't forgotten about this. Just still haven't had enough time to support having the truck unavailable for 1 day...and I'm looking for a airbag to go with the F-150 steering wheel
I actually found your X swap thread and it gave me a ton of helpful hints/heads ups for when I do my swap.
The 99-07 wheel itself is decent, but the F-150/Expy variants are much better IMO. They are more ergonomically setup, and the button placement is more intuitive for operation without looking at.
#29
