P20E8..... DTC Code. Fixed - Ford Truck Enthusiasts Forums
Old 08-11-2011, 07:00 PM
lexustbs's Avatar
lexustbs lexustbs is offline
lexustbs is gaining momentum as a positive member of FTE.lexustbs is gaining momentum as a positive member of FTE.
I have been running this truck HARD recently. Today on my way home I got the mesage for 50 miles till my DEF was out but lucky me I returned to the yard when 1 miles left was up. Well heres where the problem starts.... I get back in the truck and it says in 0 miles till 55mph limited and the check engine light was on as well? I took a code reader and read the code of P20E8 which means there is low pressure in the DEF pump. I reset the code and drove about 60 miles with no light.
My thinking is the truck got confused about no DEF and was trying to pump it with nothing in the tank. It must of been just the exact timing of how I stopped with 0 miles to go. Anyways... problem fixed!
Would like to add how great this truck has been this week. I've been hauling machines and material all over God's green earth and it has been nothing but great!
Old 08-11-2011, 07:29 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
I had the same thing happen to my truck, but I had around 200 miles to empty on the DEF. I was travelling at the time so I took it straight to the local dealer and begged them to look at it that day. They tested the system and found normal flow and determined that it was simply because of the low fluid.
Not sure exactly why, but it didn't happen again.
Old 08-11-2011, 07:52 PM
Rutcutter's Avatar
Rutcutter Rutcutter is offline
Rutcutter has a good reputation on FTE.Rutcutter has a good reputation on FTE.
So you got the message when there was only 50 miles to empty?
Old 08-11-2011, 08:08 PM
BRUTUSIII BRUTUSIII is offline
BRUTUSIII is starting off with a positive reputation.
I had to add DEF to my traveling checklist. Last month I was heading to the outter banks when 1/2 hour from home, I got a 800 miles of DEF left. By the time I got to the outer banks 7 hours later, it was saying 200 miles left. I was pulling a fifth wheel, so understandable. I have 10k on the truck and filled the DEF at 5k. Anyway, I had to drive a half hour to get DEF, but never did run out. Now I keep a gallon in the truck
Old 08-11-2011, 08:21 PM
lexustbs's Avatar
Quote:
No I recieved the normal messages as well.....
Old 08-11-2011, 11:42 PM
porthole's Avatar
porthole porthole is offline
porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.
Quote:
'cause ya sold the truck and Mustangs don't have DEF
Old 08-12-2011, 09:13 AM
Tom's Avatar
Quote:
Haha...yeah I guess you have me there.
Seriously though, this was at around 6,000 miles and I traded around 10,500.
Old 12-20-2011, 08:35 AM
Tethergrain's Avatar
Tethergrain Tethergrain is offline
Tethergrain is starting off with a positive reputation.
code hut!
My F550 2011 threw this code as well, just yesterday in fact. it said two codes but was only able to display the P20E8. I recall before that I had a msg that said low DEF or something to that effect, this time, chk engine lite, I drove 340 miles that day and no other msgs. I have not added any fluid, b/c I added some this past weekend, WTF?? I'll reset it, chk the level,
DEF Problems nb443 2017 Super Duty 3 11-26-2016 12:19 AM
New truck = new problems def heater and p0401 79f-250custom 6.7L Power Stroke Diesel 10 08-07-2016 08:17 PM
Bad DEF??? blenhardt 6.7L Power Stroke Diesel 14 02-15-2012 03:49 PM
DEF Tank replaced slangvel 6.7L Power Stroke Diesel 12 09-06-2011 03:46 PM
Another 6.7 Problem Gowa69 6.7L Power Stroke Diesel 4 12-20-2010 11:34 PM
Tags
11, 2011, code, codes, cylinder, diagnostic, diesel, dtc, f250, f350, ford, ion, p20e8, powerstroke, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
