limited slip not working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-11-2011, 02:06 PM
96_F250_Deezal 96_F250_Deezal is offline
96_F250_Deezal is gaining momentum as a positive member of FTE.96_F250_Deezal is gaining momentum as a positive member of FTE.
Question limited slip not working
this is on my 2006 F-250, I have confirmed it was equipped with a 3.73 LS rear diff. it doesn't appear to be locking anymore, only 1 wheel is spinning.
Is there anyway to correct this? I know Ford sells traction lock rebuild kits for the 8.8" rear diff in cars and F-150s
I looked at several aftermarket units, like the lock rite unit from Richmond gear, but no one offers anything for this rear diff with the 3 pinion carrier.
POWERTRAX® LOCK-RIGHT LOCKER BY RICHMOND
so, any ideas how I fix this? I want some sort of limited slip or locking rear diff.
rebuilding or repairing the stock unit is preferable, but if I have to replace it with a aftermarket, I will consider it.
Eric
Old 08-11-2011, 02:37 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
You could try new oil without friction modifier, and see if the old unit will lock up at all before putting in a more correct amount of modifier.
Eaton TrueTracs and Detroit lockers are popular, the stock Auburn unit is kind of a POS, notorious for the clutches burning out.
Old 08-11-2011, 03:15 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Once you've burned out the stock LS, which is what has happened, I would not rebuild it with OEM components. It just isn't worth polishing that turd. Either do without LS, or step up to a TruTrac.
Old 08-11-2011, 03:20 PM
maverick22's Avatar
maverick22 maverick22 is offline
maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.maverick22 has a good reputation on FTE.
As much as it pains me, I have to agree w/ a red raider. Bryan is correct in his assesment. I've got a 2005 w/ the same rear and the same problem. I'm almost due for an oil change in the rear anyway so I'm going to try it w/out any modifier and see if it works and if it chatters going around corners - if it works but chatters I plan to add the modifer in small amounts until it stops chattering. If all of that fails I'm putting a trutrac in. It's really disappointing b/c I have a '95 F150 w/ the factory limited slip w/ almost 160,000mi and that thing still works amazingly well.
The theory behind all that is there was too much friction modifier installed from the factory and it lets the clutches slip too easily. Whether removing it will work remains to be seen. Personally, if yours is shot, I woudn't suggest rebuilding it - it's still a clutch system and prone to failure. The TruTrac is a gear drive system so it's much more robust and reliable.
Old 08-11-2011, 03:40 PM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
my 06 has a whopping 10,000 miles and I know for a fact that my LS is pretty much dead already. When i got stuck over the weekend only the drivers rear tire was spinning. As previously mentioned, the F-150 LS is a much better unit. My 2006 was supercharged and the 9.75 axle with LS held up to tons of abuse from me on/off the road.
Tru-Trac replacement is my solution when I get new gears
Old 08-11-2011, 05:09 PM
I would be all for a tru-trac... but I don't find a listing for the 2006 F-250 with the 10.5" rear diff.
Old 08-11-2011, 05:15 PM
Disgruntled Texan
Old 10-25-2011, 05:48 PM
Old 01-24-2012, 06:17 PM
Benny76's Avatar
Benny76 Benny76 is offline
Benny76 is gaining momentum as a positive member of FTE.Benny76 is gaining momentum as a positive member of FTE.
I'm bringing up an old thread fellas, but want to tell my story to see what you think. My LSD was working fine. About 3k miles ago I had the entire truck serviced for the 60k mile service and they changed the sythetic fluid very early at my request. I thought I've almost noticed a slip when accelerating just off dead stop then it goes away. Today it actually rained so I'm poured the coals to her on a wet street (didn't wanna do it on dry pavement just because I don't like stressing it like that) in a slight right turn and it was peeling just the right tire the entire time. Is mine shot? Should I change the fluid without the friction modifier. The truck had an easy life. Is it just a POS diff. It's still under warranty so I can take it in to get it fixed if need be but I hate dealing with the stealerships.
Old 01-25-2012, 03:06 AM
EODguyJake's Avatar
EODguyJake EODguyJake is offline
Fulltime INFIDEL!
EODguyJake is starting off with a positive reputation.
It's a turd LS, like everyone says. Mine was trashed before 60K, and I don't do anything crazy. Stepping up to a tru-trac was outstanding.
Old 01-25-2012, 07:29 PM
simulatedjim simulatedjim is offline
simulatedjim is starting off with a positive reputation.
I have heard about someone taking theirs in for the LS and the tech put the front tires against the curb and tried to spin the tires and when they didn't spin said its working fine?
Old 01-25-2012, 11:01 PM
Benny76's Avatar
Quote:
I'll kill em! I have an inboard camera, they that without me knowing about it even if I'm not there. If I ever saw that I would be extremly pissed. They better be opening it, putting a dial indicator on the ring gear for backlash, checking for pinion depth, and checking clutch wear with some feeler gauges. I can't see that on my camera but I'll damn sure see that test if the do it.
Old 01-27-2012, 11:41 AM
I had the traction lock in my truck rebuilt in November. it works now, but not as well as I would like it to. eventually, I will get a true track in the rear and a e-locker in the front, might go to a 4.10 gear too.
Old 01-27-2012, 11:58 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Quote:
That sounds like mine is from new. The stock LS unit is pretty pathetic. Even on wet grass you can get it peg leg sometimes. I agree with what was said "not worth polishing a turd, get a Truetrac".
Old 01-28-2012, 01:02 AM
Benny76's Avatar
Ok. I do like the gears better than the clutch packs. So FX4 equals ugly skinny little skid plates, turd limited slip, and sticker that is welded to the bed and refuses to come off nicely? Got it! Oh well, it was on the truck when I bought it. NICE avatar by the way!
L/S to locker with a 10.25 - 89 f250 FordMuddin' Offroad & 4x4 10 03-09-2011 04:49 PM
Richmond Powertrax Lock Right For Sterling 10.25 ceetwarrior Clutch, Transmission, Differential, Axle & Transfer Case 11 03-05-2011 11:09 PM
10.25 limited slip rebuild goodB0Y Offroad & 4x4 2 12-15-2008 11:36 AM
Powertrax Lock-Right Lockers ... any good? biltfordtough Clutch, Transmission, Differential, Axle & Transfer Case 10 01-20-2008 09:29 PM
PowerTrax into factory LS diff climbhightree Aftermarket Products 2 03-12-2005 10:05 PM
Tags
2006, 2010, burnt, change, duty, engaging, f150, f250, factory, ford, limited, oil, slip, spin, super, superduty, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
