limited slip not working
You will get a "working as designed" from the dealer more than likely. The diffs can usually be rebuilt with more preload on the clutchpack for better performance (less slip from the clutch pack) however that will reduce the life of the friction material. Plus until you have someone pull the old diff, rebuild it and reinstall it your better off just swapping in an aftermarket unit and done.
Ok, instead of starting a new thread I'm bumping this one to see what people think. I read an article on this L/S diff that says you can tear it apart and change the combination/ orientation of the axle clutch plates and the housing clutch plates, and maybe even add a few in there, to make this thing work. For the big price of 81 bucks plus axle seals. Has anyone heard of this or done it. Way cheaper than a new carrier. Here is the article I speak of. Ford limited slip rebuild
In theory anyway, increasing the friction surface amount should increase the amount of force it takes to allow slippage of one wheel.
If you can do all the work yourself it would be something to experiment with. If you have to pay someone to do the work for you well....probably not. One of the main things I have against a clutch type diff with friction material is it contaminates the oil as the friction material wears. This spent material obviously gets into the oil and recirculated throughout the axle and into the bearings.
my 06 has a whopping 10,000 miles and I know for a fact that my LS is pretty much dead already. When i got stuck over the weekend only the drivers rear tire was spinning. As previously mentioned, the F-150 LS is a much better unit. My 2006 was supercharged and the 9.75 axle with LS held up to tons of abuse from me on/off the road.
Tru-Trac replacement is my solution when I get new gears
I am pretty certain that is the way it works and is designed.
PsRumors
12-10-2003 04:20 PM
