2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
What is causing my Exp to feel like I am on a rumble strip?
Old 02-02-2017, 03:09 PM
PAPutzback's Avatar
PAPutzback
PAPutzback is offline
I am hoping it is just a cupped tire because the noise seems to coincide with running on a low tire for a couple days. I have had bad luck with the tire sensors and just figured this was a false reading that would go away on a warmer day. But my pressure was down about 4 lbs on a tire.
Searching the web I found many rumble threads on various Fords but the diagnosis was usually related to carrier bearings, u joints, transmission fluid changes...
My first step will to get the tires rotated to see if that helps or moves the vibration to another location. After that, what would be my next step if the vibration comes from the same location?
Addl info. It is a 2008 Eddie Bauer with 156K miles.
Cajungal08
1999 to 2016 Super Duty
04-24-2011 02:51 PM
tigman_tim
09-09-2010 04:16 PM
3fan
2004 - 2008 F150
09-09-2005 08:04 PM
mike1998
1997 - 2003 F150
06-18-2004 12:44 PM
mikehart929
1997-2006 Expedition & Navigator
01-17-2004 12:31 PM
Quick Reply: What is causing my Exp to feel like I am on a rumble strip?
