Change 4.6L rod bearings with engine still in vehicle? 02 Explorer - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 04-29-2013, 09:17 PM
jayton4 jayton4 is offline
jayton4 is starting off with a positive reputation.
  #32
Old 04-30-2013, 07:19 AM
erikjohn erikjohn is offline
erikjohn is starting off with a positive reputation.
Cool thanks James. I was able to identify mine as well to be of the six bolt variety. Well I guess I will go ahead and order a reman crank to install next weekend.
  #33
Old 05-06-2013, 08:16 AM
I pulled the motor this weekend and it was a total nightmare. That thing was a huge PITA to get out. Not looking forward to putting it back in.
Tried all of your tips but ran into some snags.
Can't get to top passenger bell housing bolt without removing manifold and even then I had to use a thin head 1/4" flex ratchet and wedge it between the hard lines that run against the firewall.
Couldn't get the wiring harness to come with the engine cause could not get to couple of plugs to disconnect up on top of the trans and could not get harness to clear the heat riser tube which was basically rusted connection to the manifold and would not budge and couldn't get access to get a wrench on it anyway.
AC compressor has studs. How and the heck could you ever get that off with the engine in the truck? I got it off by lifting the engine way up so it would drop down then pulled the front stud with a vice grip to the compressor to drop down.
Had to unhook lines from the power steering cause I couldn't get st the bolts to let it loose.
I am really dreading putting it back in.
EJ
F450 Hydroboost into Bumpside Pickup Cracker289 1967 - 1972 F-100 & Larger F-Series Trucks 20 07-18-2015 03:59 PM
My 7.3 oil pan fix (probably temporary) wildstang 1999 - 2003 7.3L Power Stroke Diesel 5 05-16-2013 04:57 PM
Part # for coolant crossover gasket on 2002 4.6L SOHC intake manifold jayton4 Modular V8 (4.6L, 5.4L) 2 07-29-2012 05:09 PM
Prepping for 4.6L engine swap in Explorer jayton4 Modular V8 (4.6L, 5.4L) 2 10-09-2011 01:08 AM
HPOP res drains after HPOP failure. bulla 1999 - 2003 7.3L Power Stroke Diesel 32 02-26-2011 01:38 PM
Tags
2003, 46, 46l, bad, bearing, bearings, bolts, cap, change, engine, expedition, explorer, f150, ford, hours, labor, rod, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
