Synthetic oil a Waste or Worth it?
Old 09-23-2015, 02:50 PM
aitg's Avatar
aitg
aitg is offline
  #77
Old 09-23-2015, 03:02 PM
aitg's Avatar
aitg
aitg is offline
Originally Posted by aitg
While Kendall and Motorcraft are both Phillips 66 products, they are not the same. Kendall and one other (Conoco?) use Titanium as an additive. Motorcraft does not, or did not as of 2011.
After doing some reading at the Phillips 66 website it appears that Kendall is the only gasoline engine oil using the Titanium additive package. Each of their brands (Phillips 66, Conoco, 76 and Kendall) use Titanium additive packs on their HDEO products.
  #78
Old 09-23-2015, 08:23 PM
meborder's Avatar
meborder
meborder is online now
Castrol uses titanium on their edge lines. Both black and gold use titanium now, the gold uses considerably more, though
  #79
Old 09-23-2015, 10:00 PM
CuNmUdF250's Avatar
CuNmUdF250
CuNmUdF250 is offline
worked for a company a couple years ago that has been around for 20 years and has had a fleet of 15-20 vans on the road everyday in Phoenix (hot,hot,hot).......once had a conversation with the mechanic who maintains those vans about the bargain Napa brand oil they used......his take was the vans were expected to go 200k and that in his 10 plus years working for the company that was what they went as the rest of the van typically started to fall apart around the still running engine......point is its still just oil.......no matter the hype
2000F-150XLT
Oil & Lubrication
18
06-30-2016 07:54 AM
soupy1957
2009 - 2014 F150
31
01-05-2013 05:15 PM
brandon_oma#692
12-21-2009 11:19 AM
jman724
Oil & Lubrication
32
01-17-2006 09:00 AM
StorminTexan
3.8 & 4.2L V6
19
12-06-2004 02:06 PM
Quick Reply: Synthetic oil a Waste or Worth it?
