SD MAF Carb discussion.
Old 08-11-2011, 12:08 PM
muscletruck7379's Avatar
muscletruck7379
muscletruck7379 is offline
less than 300 for the computer (one to build, if you can solder and follow directions, its brainless)
This is who I got mine from and there customer service has been amazing! I even have thier fuel injection book (great for learning about any kind of FI system)
Megasquirt Kits / Assembled Engine Management Systems, Wideband o2 Sensor Systems and tuning products - DIYAutoTune.com
and yeah, MS is SD.
Old 08-11-2011, 12:22 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
I think a lot of people look at the MAF swap and ditch the idea b/c it looks so complicated on the computer screen. Things you have to do like rewire your harness to get rid of the batch fired injectors and wire in new injector wires for sequential EFI and move around several wires in the EEC connector, but it's really not that difficult. MAF will do everything your wanting w/ a tune and will also run smoother and possibly stronger than the carb will.
Like said above, the stock 19lb injectors may not support 400hp, but 24lb injectors should support that no problem. The stock 5.0 truck intake shouldn't have a problem with 400hp. It flows pretty good air.
Here is a color coded chart for which injector wires need to be moved, and where your moving them along with the injector wires your adding in for an MAF swap. http://farm5.static.flickr.com/4017/...d936b8da_o.jpg
Old 08-11-2011, 01:13 PM
Ford_or_Nothing's Avatar
Ford_or_Nothing
Ford_or_Nothing is offline
So this might be a dumb question but can you rewire the injectors to get rid of the bank firing injection but still keep SD? it seems to me that would give you better milege thats really all i want ive got enough power but when i tow something heavy my milege hits the toilet and i bet some of that comes from the bank firing injectors
Old 08-11-2011, 01:14 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
Originally Posted by Ford_or_Nothing
So this might be a dumb question but can you rewire the injectors to get rid of the bank firing but still keep SD? it seems to me that would give you better milege thats really all i want ive got enough power but when i tow something my milege hits the toilet and i bet some of that comes from the bank firing injectors
No, because the computer will STILL bank fire the injectors.....Just the nature of the beast....
Old 08-11-2011, 01:29 PM
Ford_or_Nothing
OK bud that makes sense so i have the 5.8 and the E40D so i need to get a stand alone trans controller or a C6 haha and a new computer from a mustang or a lightning first gen and then i have to have it mapped and then i need a MAF sensor? thats probably gonna cost more than the whole truck did and for what, 5 more mpg and the possibility of more power so i can blow up my E40D haha its not really worth the trouble is it ?
Old 08-11-2011, 01:34 PM
SideWinder4.9l
You'll have to get a TwEECer unit, or something of the like...Mustangs didn't come with 351w....So a A9L 302 computer won't work...
And technically, given fluid and filters have been changed somewhat regular...that E4OD will last very well.....COuld always use a shift kit....
Also, as to the MAF sensor, etc....If you simply get the TwEECer unit, etc...you won't need MAF....
But if you DO go ahead with the swap....Find a late 95/96 model truck to yank the ENTIRE wiring harness, injectors, computer, etc from..
But simply enough a SD computer editor will suit your needs....
Old 08-11-2011, 01:54 PM
muscletruck7379
the MSIII is sequential, and SD im practiacally becoming a salesman!
oh yeah, and they have an add-on tranny controller
however at that point you would be better off with a newer ford computer and a tweecer like sidewinder suggested. although sequential would do more for drivability and emissions. i have heard before that it is only good for about 1/2mpg over batch. wideband control would be more beneficial.
Old 08-11-2011, 02:03 PM
Conanski's Avatar
Conanski
Conanski is offline
Originally Posted by 1800joedaddy
The stock intakes, TB's and injectors will supply that much?
No.. but a stock 4bbl carb and intake won't either so it's a wash in terms of cost.
Old 08-11-2011, 02:09 PM
Conanski's Avatar
Conanski
Conanski is offline
Well yes actually but you would have to also use the one and only sequential SD computer ever produced from an '88 Mustang 5.0HO, but it doesn't support the computer controlled transmissions of course.
Nope, that's physics and there is nothing you can do about it, a heavier load takes more energy(i.e. fuel) to move. No vehicle gets good fuel milage when towing not even the new trucks.
Old 08-11-2011, 02:13 PM
lew52's Avatar
lew52
lew52 is offline
.....The mustang computer will run the 351 , the problem is that it won't run the trans , the 94-95 302s where SFI , MAF but i think most of them were 4R70Ws , so im not sure that it would work on a E40D ??...The 351 got MAF in 96 but that would be OBD II....Lew
Old 08-11-2011, 02:21 PM
SideWinder4.9l
The reason I said it would work, is because you yourself have mentioned that the stock Intakes, etc flow just as well, etc as the high $$$ ones....Albeit a nice P & P style work couldn't hurt it...lol
Old 08-11-2011, 02:28 PM
1800joedaddy's Avatar
1800joedaddy
1800joedaddy is offline
More about the MS...?
  #28
Old 08-11-2011, 06:08 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
Rather than gumming up this thread, I'd be interested in a new thread about the MS system since I'm interested too.
  #29
Old 08-11-2011, 09:15 PM
Conanski's Avatar
Conanski
Conanski is offline
You can't lump all the stock intakes together and make that comment however, the 5.0 truck and Explorer intakes are big enough to support better heads and more displacement and have additional potential with porting, but the 5.8 truck intake isn't nearly as good and the HO is too small for anything except a 5.0 with stock heads.
  #30
Old 08-12-2011, 12:39 AM
SideWinder4.9l
There ya go...Din't mean to make such a bland statement....I'm still learning....
I just remembered you saying the factory 5.0 truck intake flowed pretty much as well as a aftermarket one.....To spend the money for other things...
Quick Reply: SD MAF Carb discussion.
