how to remove broken engine fuel filter cap - Ford Truck Enthusiasts Forums
Old 08-10-2011, 09:28 PM
06 F-350 King Ranch 06 F-350 King Ranch is offline
06 F-350 King Ranch is starting off with a positive reputation.
Anyone have a good way to get this thing off? I broke the hex part with my 1/2in. drive wrench and there's not enough for a socket to grab or the wrench so I cant get the engine fuel filter cap to loosen.
Old 08-10-2011, 09:31 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Hammer and a chisel. Tap the edge of the cap counter-clockwise, but be careful not to bugger up the aluminum housing.
Old 08-10-2011, 09:42 PM
Ok I'll keep working on it. Anyone else have any suggestions?
Old 08-10-2011, 10:04 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
can you just stick a 1/2 drive breaker bar in the center
tats how I get mine out anyway I dont usse a socket
Old 08-10-2011, 10:26 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
I'm bettin' thats how he broke it Benny!
Old 08-10-2011, 10:39 PM
Yep chisel worked. Thanks
Old 08-10-2011, 10:46 PM
BLADE35's Avatar
Quote:
I was thinking that to
I dont crank mine down so hard and oil the oring before
I wonder what the tourque spec is on it
cant be much Im guessing no more than 10-12/ft lbs
Old 08-10-2011, 10:51 PM
BLADE35's Avatar
well I couldnt find it but the oil filter cap was 18ft/lbs Higher than I would have thought
Old 08-10-2011, 10:54 PM
BLADE35's Avatar
Quote:
glad it worked out
right on steve
I probably shouldnt do mine like that anymore I probably even have a socket somewhere
Old 08-10-2011, 11:13 PM
I have never changed mine before since it was done at the time of purchase. I bought the truck used with 72k on it. Once I got the cap off I wanted to clean the housing out in case I got little bits of plastic from using the chisel in there. Good thing I did because there was broken bits off of the inside of the cap where it contacts the filter (way down inside the housing, from ahwile ago I think) and an old o ring from an old filter.
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
I stripped mine as well, both the outer edge and inside part. I'm leaving it that way until my next fuel filter change which is 10,000 miles away and for me thats about a year and a half. I plan on loading up a half inch drive breaker bar with gorilla glue, sticking it in the center, and turning it once it dries. Hopefully it works. And FWIW the cap barely requires any torque at all. I set my wrench to 20 lb fts (lowest it goes) and that was enough to strip it.
Old 08-11-2011, 01:47 AM
lakewood's Avatar
lakewood lakewood is offline
lakewood is gaining momentum as a positive member of FTE.
now that you fixed it.... next time use a socket, if i remember correctly the in-engine fuel filter uses a 24 mm, and the in-line uses a 36mm, just FYI, i bought a 36mm by it self from advanced for like 9 bucks, you can use it for engine oil cap also.
Old 08-11-2011, 07:26 AM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
If you don't have a 36mm socket a 1 7/16 will work just as well.
Old 08-11-2011, 10:18 AM
Ian123's Avatar
You can also rent a 36 mm from most auto parts stores for free
Old 08-11-2011, 01:40 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
You can buy the 36mm Lisle socket pretty cheap.
Amazon.com: Lisle 14500 Oil Filter Socket: Automotive
It's nice, because it's very thin, and it's 3/8's drive, so you can use a smaller ratchet. You don't need a big one anyway.
Personally, in my opinion, a 6 point socket is less likely to cause damage than a 12 point socket. So I managed to find a 6 point 24mm for the upper filter as well.
strap wrench for fuel filter gsxr1300 6.7L Power Stroke Diesel 24 07-27-2014 09:15 PM
Help, can't get fuel filter cap off. :( RavageX 1999 - 2003 7.3L Power Stroke Diesel 16 12-01-2012 09:45 AM
Fuel filter change no start Rudiak 6.4L Power Stroke Diesel 16 01-10-2011 04:35 PM
Do most use torque wrench on fuel/oil filter caps? danocross 6.0L Power Stroke Diesel 22 12-20-2010 06:48 PM
HELP! Cannot get oil filter cap off? What is the trick? F 250 6 liter 6.0L Power Stroke Diesel 16 09-03-2010 08:01 PM
Tags
2004, 60, cap, davidson, delete, diesel, enthusiasts, f250, filter, ford, fuel, harley, post, remove, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
