'72 crew cab on newer chassis
Old 08-10-2011, 08:24 PM
Coupleofords's Avatar
Coupleofords
Coupleofords is offline
I've finally found a donor '72 crew, and plan to put it's body/bed on a newer chassis. Thinking of '99-'04 SDuty. Hopefully, the best of both worlds. Anyone heard of/tried/thought about this? If so, what chassis would you recomend and why? Brian
Old 08-10-2011, 09:43 PM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
I haven't seen it done before on here but its been brought up acouple times nobody ever went farther then just talking about it unless they did and just haven't made a build thread on it I'm interested in doing this frame swap myself but with a dodge frame I want a cummins in my 71 crew cab from what it looks like it will be a good bit of work putting all the wiring in our trucks to make it run and function right also the body swap will need work getting it to sit on the frame also wheelbase comes into play not sure what the difference is between our years and the newer frames any info you find let me know I'm interested
Old 08-11-2011, 11:54 PM
jhooch's Avatar
jhooch
jhooch is offline
With fabrication anything is possible but it won't be easy as the Super Duty's have a much wider frame I believe.
Old 08-12-2011, 12:53 AM
wyoming4x4's Avatar
wyoming4x4
wyoming4x4 is offline
yes wider frame!
also getting tires inside fenders. But If your interested in off road racing trucks they have flaired fenders for this application. fabrication like mentioned before anything is possible. moving cab mounts around and several other things. good luck!
Old 08-12-2011, 11:30 AM
BradyCouchman's Avatar
BradyCouchman
BradyCouchman is offline
Xteme 4x4 did this a bit ago. I would check it out. Didn't look like to much work. I am sure it was a lot but doable
Nsaan
1999 to 2016 Super Duty
04-04-2013 05:07 PM
jgoodman6891
07-01-2012 03:09 PM
vinlin95
08-13-2007 10:08 AM
phunksoulbrotha
02-19-2007 07:50 PM
NMf250
10-10-2004 10:05 AM
Quick Reply: '72 crew cab on newer chassis
