Hedman Hedder install w/pics
#31
Thanks for the gasket pic, that's nice. Hopefully, the set I got comes with the same hardware/gaskets. I'll find out when I get home tonight
One thing I noticed was that I checked the instructions on their website, and they say to use the stock studs. Since I don't have them anymore (thank god), I hope that they do come with bolts long enough to make me happy - the ones that came with the eBay headers were useless, as they didn't go far enough into the aluminum heads to make me use them. I went for longer zinc-plated grade 8's.
The following users liked this post:
#32
I did check the mileage for the trip to town (filled up at the same pump before and after). It was right at 14.5 mpg with 70 miles of it on the highway (68 mph) and 30 miles in town. That's right at or just a little better than before the header install. Of course, one trip really isn't statistically significant. For the rest of it, I'm sure my mileage has gone down some because I can't seem to keep my right foot under control. Plus, I also installed a Transgo Tugger kit since the header install and the truck shifts so much better it's hard to drive like I used to. I keep telling myself I need to drive like I normally do, but that extra throttle response and crisp shifting is just too enjoyable.
I will be pulling my boat 200 miles this weekend. I've made this particular run 4 or 5 times since I bought the truck and typically get between 10.3 and 10.5 mpg. I'll post my mileage numbers when I get back. And, after I finally burn through a couple of tanks driving normally, I'll post those numbers too. But it's gonna take a while.
#33
#34
#35
First, the non-ceramic coated headers aren't painted, they're just primed. And second, I'm not sure what numbers you're using to get a $275 difference. I paid $577 for the coated headers I got. $577 minus your $275 = $302, then you still have to prep and paint them. Have you seen the primed headers that cheap? The cheapest I found was $439 shipped to Alaska, for a difference of $138. And, even if I thought that was too much to pay for the added benefit of the ceramic coating, the primed set would have taken a couple of months to arrive, which puts me into winter. And I wasn't about to be laying in snow swapping headers just to get the cheapest deal I could find. (Sometimes cheapest isn't best.)
So, for me, there was more to the equation than just price. But, if cost is your biggest factor, I'm sure the primed headers would work just fine.
#36
#37
#38
#39
#40
#41
Just checked. Part number 89660 uncoated header lists for $380 at Summit. Still would have cost me $520 with shipping to Alaska. Seems like a pretty good deal for you guys down south if you can get cheap shipping.
They want $610 for the coated ones (89666). That does seem like a pretty steep premium for the ceramic coating.
#42
#43
#44
#45
This is clipped directly from Hedman's website:
Hedman's Standard-duty, Uncoated Headers are manufactured using 18 gauge, mandrel bent primary tubes (some models built using thicker 16 or 14 gauge tubing), and 1/4 flanges (some models use 3/8" flanges). The factory black paint applied to uncoated headers is not hi-temp, and is for pre-installation protection only. For the ultimate in protection against the elements, we suggest Hedman's Original HTC coating. All Hedman street Hedders are MADE IN THE USA, and are backed by a lifetime warranty against manufacturing defects!
