Hedman Hedder install w/pics - Page 5 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
  #61
Old 12-14-2011, 12:26 AM
ak-angler's Avatar
ak-angler ak-angler is offline
ak-angler has a good reputation on FTE.ak-angler has a good reputation on FTE.
I think those "tube-like looking jobbys" you're talking about is the EGR system. And no, there's no provision for EGR on these headers. I don't know about Utah emissions laws, but they likely won't pass without the EGR if it came from the factory that way. But, I do believe the Hedman's did get an EO number issued, so the headers themselves should be "50-state" legal.
  #62
Old 12-14-2011, 12:30 AM
barthel's Avatar
barthel barthel is offline
barthel has a good reputation on FTE.barthel has a good reputation on FTE.
Quote:
Is that a technical term???
  #63
Old 12-27-2011, 04:36 PM
ak-angler's Avatar
Quick update -
After living with the exhaust leak for a couple of weeks, I finally got a chance to crawl under the truck in the daylight and give the headers a thorough inspection. I'd have done it sooner, but with all the snow, and then the melting snow, and then more snow, and then blowing snow, I wasn't very motivated.
It turns out that the manifold bolts were pretty tight, as were the CAT flange bolts. But, the collector bolts were all loose - both sides. I'm not sure if the nuts had backed off, if the bolts stretched, or if the collector joints just seated better than they were. But, each of the nuts took about a quarter-inch or more of thread before getting tight.
So, it's all tightened up now, and there's no more exhaust leaks. We'll see if it stays that way.
EDIT: After looking at the pics from the original install, I would have to say that the nuts didn't back off. So, either the bolts have stretched, or the collector joints have seated differently. I'm betting on the bolts stretching. I'll keep an eye on 'em.
  #64
Old 01-19-2012, 10:32 AM
bakon bakon is offline
bakon is gaining momentum as a positive member of FTE.bakon is gaining momentum as a positive member of FTE.
I have had these Hedman headers for a couple years now. I can say the only problem is the collector flange bolts. Lost mine the first day.
Second set loosened in two days.
Welded the nut and after two weeks leaked again. Joint was loose.
Locking washers, no help.
Double nutted for a while, still loosened.
Double nut with fine thread bolts, still loosen.
Broken bolts, replace.
Now the flanges are much closer together and the original bolt length is too long, down to the area of bolt without threads.
All thread bolts, double nutted, still loosens about every two months.
I believe the collector gets the movement from the engine to chassis. The slight back and forth causes the collector to loosen and possible push inside, pipe stretch or something. The collector flanges on my truck are at least 2 inches closer than when first installed.
  #65
Old 01-20-2012, 11:15 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I'm having basically the same thing. Like you, I think the ball-and-socket is collapsing over time. It SHOULD stop at some point - I hope.
I've thought about using some pretty strong springs, about 1.5-2 inches long uncompressed, tightening the bolts down far enough to almost fully collapse the springs and then leaving it and see what happens. Gotta find some good springs for that though. If they'll even fit with the amount of room I have in certain areas.
I think I'm going to contact Hedman about it - maybe they have some words of wisdom on the subject.
  #66
Old 01-20-2012, 03:02 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I'd get some replacement Grade 8 bolts and some mechanical locking locknuts to put on it. You can't use a nylok it will just melt but you can use the distorted thread or other type mechanical locknuts.
  #67
Old 01-20-2012, 03:12 PM
Krewat's Avatar
dkf, I've already done that, AND double-nutted it, and they still came loose. Twice.
Frustrating... I'm hoping that the ball-and-socket collector eventually stops slipping together more and more
  #68
Old 01-20-2012, 05:35 PM
dkf's Avatar
dkf dkf is offline
I guess that is probably why Doug Thorley does not use that type of connection then. Worse case cut the sections out, slip over a piece of exhaust pipe and weld completely around each joint. Then send Hedman the bill for botching the design. They obviously must not have done much R&D on that set.
  #69
Old 01-21-2012, 07:47 AM
Welding has been a thought. But I think there is flex and movement causing it. Weld a solid piece and something else is going to crack. The header to head connection have stayed tight with Summit locking bolts. Never had one of those come loose. They would be a bigger PIA to fix or tighten regularly. Agree bad design on collector but otherwise great fit everywhere else.
  #70
Old 01-21-2012, 03:39 PM
dkf's Avatar
dkf dkf is offline
Quote:
I very highly doubt you will notice an issue welding it solid. Look at the design of the Doug Thorley headers has a clamped slip fit at 2 points where the pipe coming off the drivers side bank is attached. There are no ball/socket connections. After several years those connections didn't budge at all.
Here is a pic of the Thorley setup on my truck.
  #71
Old 01-27-2012, 10:56 AM
neilc88's Avatar
neilc88 neilc88 is offline
neilc88 is gaining momentum as a positive member of FTE.neilc88 is gaining momentum as a positive member of FTE.
I was thinking that a flexible exhaust section between the cat and the Y-pipe flange might help.
  #72
Old 01-27-2012, 08:25 PM
Rosson03's Avatar
Rosson03 Rosson03 is offline
Rosson03 is gaining momentum as a positive member of FTE.Rosson03 is gaining momentum as a positive member of FTE.
So i got a retarded question
which is better in the headers area.
ceramic coating VS stainless steel
  #73
Old 01-27-2012, 10:41 PM
dkf's Avatar
dkf dkf is offline
Ceramic coated stainless steel.
Seriously I'd rather have stainless headers vs factory cermamic coated steel. The ceramic coating starts to bubble and develop rust. Sending the headers off to a company that does coating yields a better job but costs a chunk of money with shipping. The ceramic header paint works ok at helping to keep rust down and heat in but it is what it is.
  #74
Old 07-05-2012, 07:47 PM
ak-angler's Avatar
Since I (and others) have been having issues with the ball-and-socket joints leaking on these headers, I sent an email to Hedman's tech support to see what they have to say about it.
...will keep you posted.
  #75
Old 07-06-2012, 09:18 AM
Krewat's Avatar
Just tightened mine up AGAIN - I replaced their bolts which were actually bending, with grade-8's. I don't see where the slack is coming from - the rings are not bending all that far, and aren't continually moving. I'm beginning to suspect that the socket side of the collector is expanding (or the ball is contracting?).
Each tightening lasts about 2-3 weeks and then I get a leak again. The driver's side is usually the one, but the passenger side has been loosening up a little each time too...
I'd really hate to tack the thing with my mig welder
Hedman Headers GaryKip 1967 - 1972 F-100 & Larger F-Series Trucks 8 12-09-2016 01:37 PM
Y pipe/catalytic converter bolts prorad 1999 to 2016 Super Duty 4 11-15-2016 12:32 PM
Modified factory v10 y-pipe sandman3510 Ford Truck Parts for Sale 4 09-10-2016 10:13 AM
Lucky Me-Hedman Header install kevinv10 Modular V10 (6.8l) 15 11-18-2015 05:29 PM
Once again, Headers on EFI 460 Antonymooreus Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 11-06-2002 09:17 PM
Tags
89666, ball, bolts, excursion, header, headers, hedman, illustration, install, pipe, socket, specs, tight, tighten, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
