Modular V10 (6.8l)
Hedman Hedder install w/pics
Old 09-01-2011, 03:06 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Thanks for the gasket pic, that's nice. Hopefully, the set I got comes with the same hardware/gaskets. I'll find out when I get home tonight
One thing I noticed was that I checked the instructions on their website, and they say to use the stock studs. Since I don't have them anymore (thank god), I hope that they do come with bolts long enough to make me happy - the ones that came with the eBay headers were useless, as they didn't go far enough into the aluminum heads to make me use them. I went for longer zinc-plated grade 8's.
The following users liked this post:
  #32
Old 09-02-2011, 05:48 AM
ak-angler's Avatar
ak-angler
ak-angler is offline
Originally Posted by Mr-Pipeline
With 3 weeks seat time...how about an update! Any change good/bad on fuel mileage? Any towing trips? I did the ebay headers with bad results and getting the itch to try again. I believe Headman headers are what Mike 5star used to perform his dyno testing!
My daily commute to work is only a 5 mile round trip. So I really don't put a whole lot of miles on my truck. Plus, I've been riding my Shadow every chance I get (54 mpg with the wind in my hair is tough to turn down). I doubt I've even put 250 miles on the truck since the install, including one unloaded 100 mile highway trip to town and a 50 mile run into the mountains with the wheeler in the bed. So, I don't really have much for numbers yet.
I did check the mileage for the trip to town (filled up at the same pump before and after). It was right at 14.5 mpg with 70 miles of it on the highway (68 mph) and 30 miles in town. That's right at or just a little better than before the header install. Of course, one trip really isn't statistically significant. For the rest of it, I'm sure my mileage has gone down some because I can't seem to keep my right foot under control. Plus, I also installed a Transgo Tugger kit since the header install and the truck shifts so much better it's hard to drive like I used to. I keep telling myself I need to drive like I normally do, but that extra throttle response and crisp shifting is just too enjoyable.
I will be pulling my boat 200 miles this weekend. I've made this particular run 4 or 5 times since I bought the truck and typically get between 10.3 and 10.5 mpg. I'll post my mileage numbers when I get back. And, after I finally burn through a couple of tanks driving normally, I'll post those numbers too. But it's gonna take a while.
  #33
Old 09-02-2011, 08:38 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Looks like they placed the o2 sensor bung in the correct location in the pipe after the collector, and not in a single primary tube. This will definitely make them an "acceptable" manufacturer IMO.
JL
  #34
Old 09-08-2011, 10:22 PM
sesh1975's Avatar
sesh1975
sesh1975 is offline
Any reason you wouldn't just go with the painted headers? If price wasn't a factor I could see getting the coated ones but from what I have found your looking at paying an extra $275.00 for the coating.
Thoughts?
  #35
Old 09-08-2011, 11:42 PM
ak-angler's Avatar
ak-angler
First, the non-ceramic coated headers aren't painted, they're just primed. And second, I'm not sure what numbers you're using to get a $275 difference. I paid $577 for the coated headers I got. $577 minus your $275 = $302, then you still have to prep and paint them. Have you seen the primed headers that cheap? The cheapest I found was $439 shipped to Alaska, for a difference of $138. And, even if I thought that was too much to pay for the added benefit of the ceramic coating, the primed set would have taken a couple of months to arrive, which puts me into winter. And I wasn't about to be laying in snow swapping headers just to get the cheapest deal I could find. (Sometimes cheapest isn't best.)
So, for me, there was more to the equation than just price. But, if cost is your biggest factor, I'm sure the primed headers would work just fine.
  #36
Old 09-09-2011, 07:20 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
ak-angler, just like you said, my collector bolts loosened up in just three days of driving
  #37
Old 09-09-2011, 11:28 AM
ak-angler's Avatar
ak-angler
I don't know why Hedman ceramic coats the collector bolts. But, I haven't had any issues since I put the tension nuts on.
  #38
Old 09-09-2011, 02:48 PM
sesh1975's Avatar
sesh1975
sesh1975 is offline
Summit has the primed headers for $375. But the coated ones are $606.00
  #39
Old 09-09-2011, 03:48 PM
ak-angler's Avatar
ak-angler
I guess that's why I didn't buy them from Summit. Well, that and the $140 they wanted to ship them to Alaska.
  #40
Old 09-09-2011, 06:26 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
These exact same Hedman headers for $375?
  #41
Old 09-09-2011, 08:31 PM
ak-angler's Avatar
ak-angler
Just checked. Part number 89660 uncoated header lists for $380 at Summit. Still would have cost me $520 with shipping to Alaska. Seems like a pretty good deal for you guys down south if you can get cheap shipping.
They want $610 for the coated ones (89666). That does seem like a pretty steep premium for the ceramic coating.
  #42
Old 09-09-2011, 10:20 PM
sesh1975's Avatar
sesh1975
sesh1975 is offline
Agreed. I have to find out what coating them would cost.
  #43
Old 09-12-2011, 07:28 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The trick is, the coated ones would be warranteed against rust-through. If you bought uncoated ones and had them coated, who's going to warranty them for you?
  #44
Old 09-16-2011, 12:04 AM
sesh1975's Avatar
sesh1975
sesh1975 is offline
From what I have been told the non-coated headers are actually painted with high heat paint. I live in socal so rust is not a real issue.
  #45
Old 09-16-2011, 01:31 AM
ak-angler's Avatar
ak-angler
This is clipped directly from Hedman's website:
Hedman's Standard-duty, Uncoated Headers are manufactured using 18 gauge, mandrel bent primary tubes (some models built using thicker 16 or 14 gauge tubing), and 1/4 flanges (some models use 3/8" flanges). The factory black paint applied to uncoated headers is not hi-temp, and is for pre-installation protection only. For the ultimate in protection against the elements, we suggest Hedman's Original HTC coating. All Hedman street Hedders are MADE IN THE USA, and are backed by a lifetime warranty against manufacturing defects!
Quick Reply: Hedman Hedder install w/pics
