Hedman Hedder install w/pics - Page 19 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
  #271
Old 07-31-2014, 08:21 PM
toddb1 toddb1 is offline
toddb1 is starting off with a positive reputation.
I'd recommend not buying them, although it was about $30 in parts it's a real time consumer. Should have built a jig!
I misplaced my wideband plug so I'll have to clean up to find it
  #272
Old 07-31-2014, 08:25 PM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
If I where you I would have tried to weld as much as I could wile it the headers where in the vehicle. I know the passenger side would be a pain, but the drivers side would be easy.
  #273
Old 07-31-2014, 09:08 PM
I welded the 3 to 2.5" reducers out of the truck so I could tig them. I fitted the pipe from the drivers side to y in the truck.
  #274
Old 01-18-2015, 08:10 PM
90turbo1 90turbo1 is offline
90turbo1 is starting off with a positive reputation.
dang it, I just read this entire post and was about to pull the trigger on a set now I am not sure again.
here are some things I have noticed. the ball and socket collector is junk, that is known across the board from header mfg to mfg. I have seen this set up on some other headers (ford thunderbird S/C) comes to mind and they don't bolt the ball collector together that header brand used very heavy springs to pinch the collectors together with no bolts. that allows it to move and flex....
second thing I was wondering is on other trucks that use this style of exhaust routing there is a slip connector directly under the transmission. I was thinking this allows the system to expand and contract as needed. so my thought is....
could a person install a stainless flexpipe section directly under the transmiision area this will allow the exhaust to expand and contract and move if needed. Asians have been using this for ever and American car companies do not. we also do not see the broken bolts and such on Asian trucks so I am thinking it has a lot to do with the cooling and heating in exhaust system.
  #275
Old 01-22-2015, 01:50 PM
I don't think it would help. Ball flanges work, even on the ebay headers I ran on the truck before without issue. The material is too thin and the cone that is formed from their design creates a hot spot since it's going from 3" to less than 2 on the ones I had. I haven't had any issues with mine since I did the slip tubes and that includes towing my toy hauler up the hills with the procharger.
  #276
Old 01-26-2015, 09:22 PM
Quote:
Yeah I can see cutting that restriction out of there and just welding in a pipe connection.. I wonder why they didn't just go with a standard header connection and gasket. I think I will get the headmans. I can do the slip pipe mod to them like you did that doesn't seem to out of this world to accomplish. after you did this mod did you have any issues. I can see the ball flange is designed to flex a bit and seal when misaligned. yours appears to be solid.
  #277
Old 01-28-2015, 09:53 AM
Quote:
I'm sure it has a lot to do with $. I didn't have any issues after, I could't go 50 miles prior. There is some room for movement in the slip joints, I don't think there is a need for a flex coupler, most of that is on transverse motors that rock back and forth. Hedman said they would beef them up, but I would eat shipping so beware if you want warranty work it'll cost you an arm and leg to ship these things.
  #278
Old 01-30-2015, 07:21 AM
hav24wheel's Avatar
I got mine Warrantied, didn't cost me a dime. BUT they do say welding on the headers voids the warrenty. Mine had a primary tube crack where it goes into the collector.
  #279
Old 02-01-2016, 03:34 PM
ak-angler's Avatar
ak-angler ak-angler is offline
ak-angler has a good reputation on FTE.ak-angler has a good reputation on FTE.
Update: Got tired of dealing with leaks at the ball and socket on the Hedmans. Just ordered a set of Thorleys. If the weather cooperates (and they actually show up), I may be doing the swap this weekend.
  #280
Old 02-01-2016, 06:54 PM
justonv justonv is online now
justonv is gaining momentum as a positive member of FTE.
Be sure to take some pics I have been back and forth on Thorleys vs Banks, I just can't make up my mind.
  #281
Old 02-01-2016, 11:51 PM
4x4pwr's Avatar
4x4pwr 4x4pwr is offline
4x4pwr is gaining momentum as a positive member of FTE.
Quote:
I have my thorley's sitting in a box.. Waiting on my shortblock to get built so I can install them.
  #282
Old 02-02-2016, 09:26 AM
I haven't touched the hedman's since I switched to slip tubes.
  #283
Old 02-02-2016, 09:36 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
After using the truck last year during some intense snow storms, and the resulting road salt afterwards, the coating on my Hedmanns is almost completely gone and the underlying metal is rotting pretty badly.
Are the Thorley's stainless?
If I'm going to keep this thing, it's going to need new headers sooner rather than later... sigh.
  #284
Old 02-02-2016, 01:28 PM
4x4pwr's Avatar
I do not believe they are stainless... However, they are ceramic coated inside and out. We don't salt our roads up here, so rusting isn't that big of an issue.
  #285
Old 02-02-2016, 04:31 PM
jay_blu jay_blu is offline
jay_blu is starting off with a positive reputation.
Sorry, my phone jumped to related a thread and my post went there.
Off road y-pipe jt351 2004 - 2008 F150 3 02-03-2013 10:49 AM
Replacing Y-pipe 351w spkennyva 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 06-02-2012 10:42 PM
The saga continues... hedmans on order Krewat Modular V10 (6.8l) 53 11-10-2011 03:01 PM
New headers on the way ak-angler Modular V10 (6.8l) 24 08-10-2011 09:55 PM
Strange pattern on brake rotor ak-angler 1999 to 2016 Super Duty 22 05-27-2010 09:05 PM
Tags
89666, ball, bolts, excursion, header, headers, hedman, illustration, install, pipe, socket, specs, tight, tighten, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
