Hedman Hedder install w/pics
#228
#230
The issue is that the bell on the y pipe gets really hot, than the bolts basically pull the flange onto the bell straitening it out. Welding the flange to the y pipe makes it keep the shape. If get a pic later today you will be able to see how much mine pulled the flange through the bell before I actually welded it. Compare it to the pic of when I first installed them
#233
#235
#237
It's been almost a year since I installed the new bulletproof headers, so I thought I'd drop a quick update. After one initial re-tightening, there have been no more leaks. So, it looks like the new design works.
Getting Heddman to make it right was a much bigger headache than it should have been. But at this point, unless other people are still having problems, I can now recommend the updated version of these headers without reservation.
#238
#239
#240
I just ordered a set of these Hedman headers from Summit and I would like to know if the bolts (for the head and Y pipe) that came with it are good enough or do I need to buy Stage 8 fasteners?
Can't wait to get these installed and not have to listen to the exhaust leak due to broken studs.
Found an exhaust shop locally that will install these headers for $250 (too good to be true right?)..........I have a feeling he will ask for me money after fighting with the broken studs.
